How to set up with component video
SOURCE: Coby 224 wrong disc
you can reset the settings through the menu, its under the advanced option in the menu. however, its not a regional error, if it was in the wrong region, it would say wrong region and not wrong disk, try putting the region back to 1 or 0 or 9, 1 is USA, 9 and 0 are all regions.
SOURCE: coby 224
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Unfortunately, Coby is a company whose electronics cannot be controlled by any remote other than the one that came with it. This means there is no code available for universal remotes. If you need a replacement remote (it will be identical to the one that came with the unit) please call our customer service number above. They will take your information and provide you with the procedure for ordering a part from Coby.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
SOURCE: philips universal remote not working for my coby dvd 224
Traditionally, universal remotes do not work with COBY dvd players. The fact that you've found one that works at all is surprising. There isn't a true solution to your problem, however, because Philips created the coding for that remote without any input from COBY. The only thing you can try is a different COBY code if there is one in the code section of the book that came with your Philips remote.
While this solution doesn't "fix" your problem, I hope that by giving you the facts, I've enabled you to make an informed decision as to what to do next.
Please let me know if I can assist you further.
