Yes you can however HP only supports Windows XP (32-Bit), Windows Vista (32 and 64 Bit) No official support for windows 7.
However Most modern PC's will run windows 7 and most drivers are available. Upgrade at your own risk.... There might be some drivers that you wont find and may cause problems with your PC.
But why upgrade to 64bit if you are not upgrading memory to 4GB+?
See Windows 7 system requirements Microsoft Windows
SOURCE: 32 BIT WIN XP MEDIA
The usual recommendation from Microsoft is Pagefile = RAM x 1.5.
That would mean a 6GB pagefile in your case, but this rule comes from a time when people had 256 or 512 MB of RAM.
The safest way to set it up is to let Windows handle the size of the page file.
If yo want to set it manually, the make the initial size the same amount as the maximum size. This results in one large file which is not affected by disk fragmentation.
If you want to read a little bit more, look at this article from Petri.
If you have any more questions, come back here and leave a comment - I'm happy to help.
SOURCE: How much memory can I add?
an addition 2GB will be enough for your system.
Take care.
Testimonial: "Thanks for your help!"
SOURCE: I have an HP m7170n
just go to this site and download upgrade advisor and it will tell you what your pc is capable off and what to do to make it compatible if needed. http://www.microsoft.com/windows/windows-7/get/upgrade-advisor.aspx. be patient since this does take longer time to run. it will give you all details you need. here is a link from microsoft site to update from xp to windows 7 with all steps. http://windows.microsoft.com/en-us/windows7/help/upgrading-from-windows-xp-to-windows-7. Hope this helps.
SOURCE: Sir, I want to install a 2nd SATA drive in a
upgrade to the latest bios and run cpuz to see if ur cpu has 64bit
SOURCE: Have an HP xw9300 with 8GB of physical RAM but
Problem: More than 2GB of RAM is installed, yet the 32-bit OS only sees 2GB.
Cause: Memory remapping is enabled.
Solution: Enter Computer Setup (F10) and disable memory remapping: Advanced > Chipset/Memory.
1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
16 GB available hard disk space (32-bit) or 20 GB (64-bit)
DirectX 9 graphics device with WDDM 1.0 or higher driver
