Cord on blower won't pull. Removed cord cover, and pulled rope. It pulls, then retracts ok. But what I believe is the "Flywheel" won't turn. It will move slightly to left or right, but no more than that. HELP!! I still have leaves from the fall that need to be cleaned up before I can mow!!
Remove plug and try pulling to start or turn with a wrench if moves put plug and try starting --if not moving motor damaged or seized
Think I solved it- I oiled up the piston and put more gas/oil mix in and forced a few pulls until it turned over- My guess is that I ran out of gas and ran on fumes for a second which burned away my remaining lube in the piston. It didn't fully seize but it jammed up a little and the new gas and oil freed it up.
Remove the sparkplug and try to turn the flywheel if it turns freely then the engine is most likely ok. if it does not turn you have a locked engine that means its toast. If it does turn then you have to look closely at th pull recoil that it is engaging the flywheel.
SOURCE: ECHO blower won't pull
I think i know how to fix it.. :)
Its got a compression lock. take off the spark plug and pull the rope.
Dont forget to rate me back please! -Jeff -Anchorage Small Engine.
SOURCE: weed eater is locked up. can not pull cord at all.
Try taking the cover off around the pull if you can. Likely the cord is not free to spin, or there is a rub on the fly wheel stopping it from moving.
SOURCE: my echo pb2100 gas leaf blowers pull cord is loose
COULD BE THE SPRING INSIDE THE RECOIL NEEDS MAY NEED A NEW ONE
SOURCE: I have a Echo PB 2601 made a loud bang then stoped working.
Sounds like it has seized up. If the pull cord won't pull then the motor is locked up. Did you run gas/oil mix for the fuel its a 2 cycle motor...
SOURCE: pull cord or motor frozen
Unfortunately, your Echo blower gets all of its lubrication from the oil mix in the gas.
To inspect the damage, remove the muffler and look inside the cylinder with a flashlight. If you can see scrathes or scoring along the sides of the piston or cylinder walls, then there are only 2 options. Repair or replace.
The repair would involve replacing the piston and cylinder (parts are $150) If you can do the labor, that would save probably $100.
To replace, I found several on ebay and other online sites for less than $300 plus shipping.
Good luck.
