Oster Golden A5 2-Speed Universal Motor Clipper 78005-140 Logo
D
Deborah Posted on May 04, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why my clipper won't turn on after I clipped my piddle?
My clipper will not turn on after I clipped my poodle
Vincent Simpson
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 65 Answers
  • Posted on May 05, 2014
Vincent Simpson
Expert
Level 2:
New Friend:
Cheetah:
Answers
65
Questions
Helped
10051
Points
102
tip
Why You Shouldn't Swap Small Clipper Blades Between Dog Clippers
Although dog clippers manufacturers claim that their clipper blades are universal (fit other dog clippers), they work best on the dog clippers they were designed for.
The socket (clipper blade), the hinge assembly and blade drive assembly (dog clippers) vary from manufacturer to manufacturer. If you are using different brands of clipper blades on different brands of dog clippers, there will not be a perfect fit.
HINGE ASSEMBLY
The hinge assembly secures the clipper blade (via the blade socket) to the dog clippers.
If the hinge assembly is not regularly replaced, your clipper blades will start to rattle on your dog clippers. The ears on the clipper blade socket are constantly rubbing against the metal hinge assembly, which consequently causes wear on both the socket and hinge assembly. You must ensure that there is a snug fit between the clipper blade socket and the hinge assembly or the blade will eventually rattle.
On average, if a groomer is clipping 8 dogs a day, the hinge assembly will probably need replacing every 12 weeks.
When replacing the hinge assembly, make sure that the screws are secure because if they are too loose the clipper blade will not cut correctly or not at all.
It is not advisable to try to adjust the ears on the socket to enable the clipper blade to fit the hinge assembly, because you will risk breakage which will render the blade redundant until you get the socket replaced by a sharpening professional. The best person to adjust clipper blade sockets is an experienced clipper blade sharpener because he has the relevant tools and should the socket snap, he has spares.
BLADE DRIVE ASSEMBLY / BLADE LEVER
The plastic lever on the blade drive assembly locks into the cutting blade and drives it backwards and forwards.
Problems occur because the black plastic lever is constantly rubbing against the metal cutting blade; so consequently, the plastic will gradually wear away. Once the lever is worn, the cutting blade won't be driven side to side as much as it should.
If the blade drive assembly is not regularly replaced, the clipper blade will leave tram lines in the coat, pull at the hair, the dog clippers will sound noisier and the clipper blade will eventually, stop cutting.
On average, if a groomer is clipping 8 dogs a day, the blade drive assembly will probably need replacing every 6 - 8 weeks.
If your blade drive assembly is worn, your newly sharpened blades will not cut because the cutter blade is not being pushed along the whole width of the clipper blade (it is more noticeable on blades where the teeth are further apart - 3,4 5 & 7). If this is the case, we would strongly recommend that you replace your blade drive assembly.
on Feb 28, 2020 • Dogs
1helpful
2answers
Clippers not cutting
It is not unknown for a sharpen to be no good, anyone can turn out a bad sharpen. Look for correct blade assembly, check that there is sufficient pressure holding the blades together, check there is no missing stroke. Check the blade is secure and not wobbling. If the above are OK I would buy a new blade. You could also return the blade with the clipper for the sharpener to test for themselves.
Heiniger clippers won't clip
It's likely the tension nut or screw needs to be tightened a little more providing the drive block is in place and the blades have been put on correctly.
You shouldn't need to buy new blades even when they go blunt just send them to a professional sharpener
Same problem as some of the other, does not cut just pulls. I went and got new blades and that didn't help either. HELP! hairy poodle!
If you have tried a new blade it must be a fault with the clipper. Usually a good place to start is the drive lever
Oster Golden A5 keep turning themselves off whilst I'm clipping
Ok turn your clipper on and hold it still in one hand whilst with the other hold the cable near the end of the clipper and bend it, rotate and twist if your clipper cuts in and out you have a break in the cable which is tricky to fit but our web site Help section can help.
2helpful
Shaver no longer cutting well
Have you been keeping the blades cleaned and oiled well? How long have you had the clipper it may be that you need a new blade? This trimmer is not truly intended to do a complete clip on a poodle it is for trimming. Please call Andis customer service at 1-800-558-9441 for further instruction.
1helpful
2answers
Andis pet clipper kit
You are most likely referring to the snap on comb.. most of them are designed to use only with a 30 or 40 blade. This is the only way you will get a proper cut with them. Good Luck with your old "guy". And I'm sorry hes petrified to go to a professional groomer.. seems you have been taking him to the wrong ones. :)
Top Oster Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Marc Messenger
Level 1 Expert
jws1013
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
