It will not self thread and looks like the attachment where you put the thread #7 is no longer attached properly.
GO TO THIS LINK..IT MAY HELP...IF NOT GO TO YOUTUNE IN HOW TO REPLACE THE SELF THREADER SPRING ON MY BROTHER PE770...http://www.ehow.com/how_7279348_fix-threader-brother-sewing-machine.html
SOURCE: Bobbin shuttle problem not solved
Did you download the manual from the link I provided? Both the normal & quick set bobbins are covered on pages 27 - 30 Here is the direct link to the manual: http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000242/xl3500_t_3510ug01enes.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: Attaching walking foot
you probably purchased the incorrect walking foot for your specific machine. check and make sure if you have a high shank or a low shank....the way to determine if you have a low-shank is to measure the screw from the plate and look at the distance if it is 5/8 then you have a low, any higher about 1in. then you have a high shank, so you would purchase a foot depending on your shank.
SOURCE: My needle broke and a piece of metal fell out of machine
just adjust to needle in fix to strait in needle clamp hole it operate to needle strait to hole so needle do nt break but needle is best buy qualtity
SOURCE: Needle thread getting caught in bobbin are on Brother Cs-100
I don't know if this is any help, but I would suggest taking it in to a repair store. So here is a way to find places that repair brothers machines. The place near me has done a great job both times I've gone in. Also they usually don't charge for labor, just parts. If they charge for labor it probably won't be much.
http://www.brother-usa.com/service/
SOURCE: needle clamp won't attach to needle bar
There is a set screw above the needle pin screw which tightens with an allen wrench--try that.
