Televison & Video Logo
A
Anonymous Posted on May 03, 2014
Driver lcd tv
39fu3253
3answers
Where can i order quality tv parts online,like lcd driver ics
U can have a look https://www.abctay.com,maybe you can find what you need the tv parts
DRIVER FOR BEKO LCD TV MODEL: NR 15LB450
What cable are you using? I'm not aware of any driver? Try the settings in the TV, select Input, select the port you have connected to the computer. Take a look at this user manual: http://www.manualslib.com/manual/351949/Beko-15lb450.html
2helpful
Half of the screen goes black, white, gray and blue lines while the other half still showing tv program
hi,
There can be two possibility for this problem. Lcd driver or the lcd itself faulty. In most cases the lcd driver will become faulty. I have added a picture bellow. There is a circuit board inside your tv like this Covered by a metal cover. Remove the metal cover. You will see there will connection on three sockets. of which 2 will go to the lcd panel and one will go to the mother board. Before replacing that board carefully remove the wires from the sockets and then reconnect the same. some time improper contact can cause this problem.After that check the tv. If then also the problem remains you have to replace that circuit board as whole.
ok
I want to use the 23" Polaroid LCD as a monitor.
use your VGA or a DVI input and set your tv to pc mode thru the tvs menu. you should not have to instal any drivers at all. your tv as a monitor will display all text and images as a monitor the same as it does as a tv
Sylvania LD427SSX lcd tv driver update for Windows xp so I can set it up via the Svideo output
you should be on windows 7 by now and there will be no driver update ur video card driver to latest on and select displays and choose your display
Bush TV LCD 32 TV 005 HD
The black screen problem of your TV can be attributed to a backlight driver failure, busted backlight, or LCD driver failure.
The flickering indicates a failing backlight driver or a failing backlight. The screen should be totally black, without any glow, when either of them is not working. To verify, grab a torch and shine it on the screen. You will be able to see a faint display telling you that the backlight is busted or the backlight driver is faulty. If not, the LCD driver or the LCD panel itself is faulty, although it has a low probability due to the symptoms of the problem. The only way to fix the problem is replacement of the faulty part. You may need the service of a qualified technician to determine exactly which one is the root of the problem that needs replacement.
2helpful
Broad panel of strips (Vertical) down approx one third of tv
It can either be the LCD driver board or the worst case, LCD panel.
4helpful
Red vertical line down right side of the screen
hi
I think your TV have a trouble inside lcd panel
the controller board contains driver IC. Deffective driver IC can cause of line display.
Three reasons why one vertical line accross screen can happen in LCD;
1.The missing signal from the controller IC to
LCD driver.
2. LCD driver IC itself defective
3. Dry contact in the tape carrier package.
Use masking or electrical tape to mark it where the line was located. press it if the line back to normal but when release your hand came back i think it was intermittent. Open the LCD panel
Use robber
Place the rubber on the top of TCP
Gently close back the top casing
Good luck...
Our 32 inch lcd sayno tv
Hello All,
I posted this earlier, however it applies here as well:
This might be a problem with the circuitry of the screen driver. what happens is the one of the drivers in the display matrix IC goes bad and it can not fire that one string of LCD elements, and this creates the line that you see. Since the line is pink, I would say that the driver is incorrectly firing the string of LCD elements. I would suggest that if you have a background in electronics you check the voltage levels on the display driver IC and the connection to the screen. If you do not have a background in electronics I would suggest that you have a qualified TV technician fix your problem.
I hope this helps,
Shuttle83
www.electron-age-technologies-llc.com
Top Thomson Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
