1. Grey, make a search on how to put the iphone into a dfu mode.
2. Download the ipsw (the iOS for 3GS) you wanna use.
3. Download Redsnow for your 3GS too.
4. USB cable for connection to PC or Mac.
STEPS
a. Having known how to put it in dfu mode, do that and connect phone to PC or Mac.
b. iTunes will detect after installing drivers for dfu device.
c.Click on restore in itunes while holding down the Shift key and you will be presented with a dialog box to choose where the iOS is. Locate it and click open or ok and itunes will take it from there.
If you experience some errors, try a different cable or pc.
Good luck.
You should just be able to plug into iTunes and restore it that way. No apps needed. No need to jailbreak (especially if you don't want to jailbreak it).
SOURCE: a usb and itune with a arrow pointing at my
restore it using itunes.then jailbreak and unlock to work properly....here's how to connect w/ itunes....you must have an internet connection to restore...
Iphone Connect With Itune
Turn Off Your Phone
Press Home Button ( 5 Second )
After 5 Second Press Power Button (9 Second )
Release Power Button
Still Holding The Home Button
Itune Detect Your Iphone In D.f.u Mode
Release Home Button
Your Iphone In D.f.u Mode With Blank Screen
done
SOURCE: iPhone 3g screen frozen with icon of iTunes -
Find the application called iRecovery. Follow the directions that are included. There are Mac and Windows binaries in the same archive.
SOURCE: I was downloading the newest
Thats called recovery mode.
All what u should do is restore it,
Download the version you want from www.felixbruns.de and connect your iphone to your itunes, press Shift + Restore and select the ipsw u downloaded and Job Done
SOURCE: how to fix my iphone
your iphone needs to be synced with itunes or activated with your service provider.
1. open itunes on your computer
2. plug your iphone in to a usb port on your computer
3. follow the instructions on the screen
SOURCE: my iPhone 3gs not work completely and in the
That means your iPhone is in recovery mode. Connect your device tonyour computer using the USB cable, open iTunes and recover your iPhone. (click on your iPhone at the left and then click the recover button)
