I have a Bosch maxx classic front loader washing machine. My problem is that the clothes are still drenched after a full cycle, the fabric softener hasn't left it's tray and we have a whirring noise that is intemitant. Any advice would be appreciated. Thanks
    New Friend:
  • 50 Answers
Sounds like a off balance load problem, run with less closes and not as heavy. see if spins out if not is the door lock light coming on?
Posted on May 04, 2014
6ya staff
SOURCE:
Anonymous
  • 213 Answers
SOURCE: Problems with fabric softener
you either have low cold water pressure being caused by the screens on both ends of the cold waterline being clogged by sediment or one of the solinoids for the water inlet is bad. try removing cold water hose and cleaning both screens if that doesnt help youll need a solinoid
Posted on Nov 20, 2007
Anonymous
SOURCE: Fabric softener dispenser does not empty on Bosch
I have a bosh washing machine and the fabric dispencer was not emptying, i took the compartment out and washed it all out making sure all the muck was off. Then i looked in the machine (where the dispencer had been) and looked up. There were some holes so i got a needle and poked it up and wiggled it, some black muck came out, i cleaned the rest of the holes and now it is working again.
Posted on Mar 24, 2009
Anonymous
SOURCE: Hard scratchy towels. Have used all wash cycles, and use fabric softener
have you tried just white vinegar as your rinse aid. Do a full cycle of your washing machine using white vinegar instead of detergent, to clean any residue from pipes, and then in the next wash try white vinegar as your rinse aid.
Posted on Apr 18, 2009
Jarrod Matthews
  • 250 Answers
SOURCE: Bosch maxx classic washing machine doesn't clean clothes
There are a lot of things to consider when trying to solve this problem. Obviously a front loader washes differently than a top loader. Top loaders tend to using a washing motion that is good for stains but wear out your clothes fast. Front loaders typically use less water and wash more gently, but in some ways still do better than top loaders. Anyway, think about any other variables that go into the laundry equation. Consider the distance the machine is from your water heater. This machine will use MUCH less water to fill than your old one, and, you know how when you turn a faucet on hot it takes a minute for the hot water to actually get there? It's the same way with your machine. If there's a sink next your washer, you should always turn on the hot water on the faucet until it gets hot right before you start the machine. The same goes for dishwashers. If there's not a sink close you can easily turn up the temperature for all hot water on your water heater, although that will use more energy.
Consider what detergent you're using. If you're using high efficiency detergent (like Tide he) maybe you should switch to your old brand. If you're using your old brand of detergent, try getting a high efficiency detergent.
Posted on Sep 20, 2009
beltronic205
Gerry Harvey
  • 1481 Answers
SOURCE: Bosch Maxx - softener not dispensing into machine
It blocks very often , give it a good clean..remove soap dispenser to do so
Posted on Sep 28, 2009
Bosch Maxx softener dispenser full of water at end of cycle
it seems that there must be a blockage in the siphon tank softener.
Remove the drawer and wash well, remove the siphon softener (just pull up)
Dec 22, 2013 | Washing Machines
I own the Whirlpool duet set with the front loading washer. The clothes comeout with a bad smell. I was told that the washer probably needed to be cleaned. How is this done, and what makes it happen?
Using the wrong kind of detergent in your fancy front loader is a great way to grunge up your washer and impart some oder onto your clothes. And it accelerates the mechanical deterioration of your washer.
2. Using too much fabric softener and/or detergent.
Liquid fabric softener does not break down very well in cold water and the residue collects on the outer tub and basket along with the lint left from the wash. We professionals refer to this accumulated as grunge. Once formed, this grunge collects ever more additional soap, dirt, grease, human waste, mites, , parasites... and then some really bad stuff.
As it turns out, this grunge makes a perfect substrate for microbial life forms. Over some time- not very much time in warmer climates- those little bacterial colonies build up lots of microbial sewage, just like we do until one day you open the door to the washer
Using too much fabric softener will waterproof your clothes. How clean do you think your clothes will get if they repel water inside the washing machine?
3. Doing all your wash loads in cold water only.
Detergents don't dissolve as well in cold water. As a result, cold water washes leave behind more grunge. So... do an occasional wash in hot water. OK, maybe more than occasional. Like, I hope you at least wash your skivvies in hot water.
4. Leaving clothes in the washer at the end of the cycle.
Front loaders don't have as much access to open air as top load machines. Consequently, leaving clothes in the washer for more than eight hours will increase mold and mildew build up.
1. Add one additional gallon of hot water to the unit before sending it into a hot wash. This will raise the water level high enough to remove the Grunge Hiding Behind the Basket
2. Same as 1 but with bleach added to all dispensers. Clean the fabric softener cup with a rag first (bleach will not break up fabric softener since it is introduced in the rinse cycle with the fabric softener).
3. Same as1 and 2 but with a cap full of pine cleaner added to the wash water (NOT the dispenser). Add some old rags (they don`t need to be dirty) and select the extra rinse cycle. The wash action will help remove the accumulated grunge from the components
Once again, make sure you're only using high efficiency (HE) detergents in your front loader.
Nov 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a dirty rubber inner Bosch Maxx 1200 Front Loading Washing
First clean around the rubber with some mould and mildew cleaner for bathrooms - available from most supermarkets.
This is a natural accumulation of waste detergent, fabric softener, fibres and dirt build up that is being attacked by bacteria and eventually decomposes into a sludge / goo and then eventually starts smelling bad as well.
To keep the machine clean of waste build up and to keep any bad odours away:
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure monthly
Oct 02, 2009 | Bosch Washing Machines
Sep 20, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Apr 18, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
Fabric softener usage on quickwash
most likely normal operation .. try a normal or heavy cycle if it works there consider it normal operation
Nov 27, 2008 | Washing Machines
My front loader Bosch washing machine is not draining in the fabric softener section.
Make sure it is the fabric softener that is not being added. Try running w/o fabric softener and see if the tray is still full. The reason I am asking is that after I run my washer the fabric softener tray is full, with water, not softener. The factory tells me it is because the water fill nozzles have realigned and overspray into the softener tray. Not a big problem, since my system is under warranty I am having them fix the nozzles and then I will know how to redirect.
If it is the softener that is not being added then check to make sure the line is not clogged. You can lift out the bleach / softener try and check for cloggs.
Aug 18, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Washing Machines Logo
238 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
