Samsung CLX-3305FW Color Laser Multifunction Printer Logo
Posted on May 03, 2014
Keep getting "Install Imaging Unit" when it is installed.
Cannot figure out why it does not recognize the imaging unit? Should have zero copies on it??
5 Related Answers
DebbyD
  • Posted on Jun 05, 2008
SOURCE: resetting the imaging unit
How do you reset the imaging unit?
henryher
  • 18 Answers
  • Posted on Aug 18, 2008
SOURCE: Invalid Imaging Unit and Toners
Sorry about my last post. I didn't realize that it would be placed unter solutions. BUT I did get a resolution from Samsung. They passed me to the advanced team and they suggested I use a special code they gave me to reset all the machine. As I said before the machine was giving me an error that all the toners and the imaging unit were invalid. Samsung said to try this and if it didn't work they would send me a new (refurb) unit. They said to press in sequence <menu><#><1><9><3><start (b&w)> then when the unit cycles it will ask to imput the country, in my case I entered the US. The machine will then reset itself and all the cartridges and imaging unit should be reset to work. IT WORKED!! The machine said to wait while it re-installs the toners. When it did the red warning light turned off and the printer is working great. Hope this helps.
Anonymous
  • 2120 Answers
  • Posted on Jan 11, 2009
SOURCE: Imaging Unit needs to be Replaced
No, what actually happens is the drum fills up with waste toner and you cannot empty it.
Anonymous
  • 2306 Answers
  • Posted on Jun 23, 2009
SOURCE: how do I replace the imaging unit in my clx3160fn?
The imaging unit is that whole assembly that the toners are plugged into inside the front door of your machine. It a consumable unit available at many office supply stores. The instructions to replace the unit are packed inside the box with the new unit.
warpspeed
  • 16 Answers
  • Posted on Oct 07, 2010
SOURCE: My Samsung CLX-3175FN is asking
You will have to purchase an new imaging drum. It is the shiny green metallic cylinder in the bottom back of the printer. It is the last piece to come out when you remove the toner waste unit and then all the toners. It sits on the very bottom/back of the toner bay. They are not cheap but do not need to be replaced very often and it will give like new printing after.
2answers
How to fix the problem error #c3-1312 , imaging unit failure of Samsung K2200ND
https://printcopy.info/index.php?mod=erc&brand=Samsung&model=ML4510ND&code=C3-1312
Link to Service Manual above for the ML4510ND model.
Quoting from link above:
Code: C3-1312
  • Display:Imaging Unit Failure: #C3-1312. Install imaging unit again.
  • Description:Toner sensor is defective. The machine can't detect the sensor signal in the imaging unit normally.
  • Remedy:1) Install the genuine samsung imaging unit. 2) If the imaging unit is already installed, check the following. • Reinstall the toner cartridge and imaging unit. • Check if the CRUM connector is normal. • Turn the machine off then on.
Another link to check, page 4-40:
http://www.electis.co.il/files/disfiles/ErrorCodes/A3%202200/K2200_Error_Codes.pdf
3answers
How do I reset ms610 imaging unit?
When you get the error message "Replace imaging unit, 0 estimated pgs remain [84.3x]" This means the imaging unit has reached end of life and needs to be replaced. The device will not print, and this message will not be cleared, unless you replace it with part number 50F0Z00
(or 500z)
Vertical streaking. If the imaging unit is near end of life, or the device has had problems with non standard toner, vertical streaks may occur on the page. Replacing the imaging unit will resolve the problem.
Vertical streaks on page
Vertical band at top of page. This typically appears on printed images, but can also appear on text. The most likely cause is toner contamination on the charge roll, however if the band is still visible after printing 30-40 continuous pages this means the imaging unit needs to be replaced.
Vertical Banding on images
Seal failure on the imaging unit. Occasionally seal leaks have been seen from the Imaging Unit.
Toner will be seen on the main frame near the Imaging Unit sides.
If toner build up is excessive, it may even fall into the Tray below. Cleanup with a toner vacuum may be needed.
Replace the Imaging Unit to fix the problem.
Spots, scratches, marks on the page. If they are random, this indicates a problem with toner scatter.If they are repeating patterns, measure the distance between matching marks or spots. If the distance is one of 97mm, 47mm or 38mm, this indicates marks or dents on the imaging unit and it will need to be replaced.
You receive the message Replace defective imaging unit The imaging unit is defective and needs to be replaced. If you just installed it, it will be covered under warranty - contact Lexmark Australia on 1300 362 192
You receive the message Reinstall missing or unresponsive imaging unit and the below instructions don't resolve the problem. Try one or more of the following:
  • Check if the imaging unit is missing. If missing, install the imaging unit.For information on installing the imaging unit, see the "Replacing supplies" section of your device's User's Guide
  • If the imaging unit is installed, then remove the unresponsive imaging unit, and then reinstall it.
  • Note: If the message appears after reinstalling the supply, then the imaging unit is defective. Replace the imaging unit.
You receive the message Replace unsupported imaging unit The imaging unit you attempted to install was either non-genuine, or was from a different region. Buy a genuine Lexmark imaging unit from an authorised Lexmark supplier in your country/region.
You receive a 31.6x error One of the following errors is shown on the display:
31.60 Imaging unit smart chip error
31.61 Imaging unit I2C packet timeout
31.62 Imaging unit I2C packet has been sent but code timed-out on receiving the data (callback)
31.63 Imaging unit security error in the send challenge sequence
31.64 Imaging unit ROM signature error
31.65 Imaging unit stuck busy (status register and/or CRI Arbiter register report busy)
31.66 Toner failed to replenish into the imaging unit
In this case you need to ensure that the imaging unit is properly installed. If yes, check if the imaging unit is supported. Replace with a supported imaging unit if necessary.
If the problem remains, you will need to organise a Lexmark service call (Australia 1300 362 192)
You receive error message 32.11 Imaging unit smart chip compatibility error This could be caused by an unsupported imaging unit (non-genuine or incorrect region). Replace with correct imaging unit to clear this error. If your imaging unit is supported, you will need to organise a Lexmark service call (Australia 1300 362 192).
You receive error message 84 Imaging unit low If expected, replace the imaging unit. If unexpected, call Lexmark Support (Australia 1300 362 192)
Replaced the K imaging unit. The new unit does not reflect it being replaced on the copier. Consumables screen shows the K unit at empty still.
"K" is refereeing to the black toner not being full.... I would replace the Black toner bottle. The toners do have a chip on them, you may have got a defective one..... Good Luck
How do I install an imaging unit
How to change imaging unit: Open the right door (R1), and you will see two green hooks, pull them out with care to remove the imaging unit installed; replace the new imaging unit and run F8.
Goodluck.
From Okorie Kodak U
Konica Minolta Di250 Imaging Unit
It is easy to install, it should come with instructions. It is like replacing a toner cartridge in fax machine. The counter for the IU unit is reset when you install the new drum unit, let it run it's setup it takes a few minutes. When it comes to READY you are done for another 60k copies.. Good Lucky
Imaging unit
No, the imaging unit will only reset back to zero if you replaced it.
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
