The master cylinder her has two piston in it separated by a plunger /pin that kicks in when fluid pressure is lost to one section. It will be necessary to remove this pin so that both pistons can work again. Sometimes this pin is a plunger of a brake switch that lights up the dash when there is a line failure. Check out a workshop manual as to how it works and the procedure to reset the pin.
