Hi Samantha,
Before you create new account in Facebook, you should have a valid email first such as @yahoo.com or @gmail.com. If you do then please follow the steps below. Hope it helps. How do I sign up for Facebook?
If you don't have a Facebook account, you can sign up for one in a few steps:
With the plug removed the starter should pull very easily.
When trying start did the cutter head try to spin?
If yes clutch springs may need replacement
If you just had serviced a month ago I would take back and tell them to fix the problem you did not have before they serviced it, or try calling maybe then can advise over the phone.
Go to http://www.worcester-bosch.co.uk/homeowner/boilers/boiler-controls/which-controls-go-with-my-boiler/mt10-mechanical-timer. They have a video and instructions plus a downloadable manual to walk you through the process. If it still doesn't work maybe you should return it a get a new one.
Just re-install the software again and your are done with this issue. Use the recovery disc that came with the computer or use a new Operating System disc be sure it is Windows that originally came or compatible with your computer. Then you can start fresh without any password needed until you do another one, HINT: I use my last four digits of my social so that I will never forget my password ever.
Either the igniton is bad or the wires are backwards. You can bypass the ignition and touch the wires together to see if the solenoid turns. You can also use an ohmmeter/voltmeter to check the current.
