Hello how can I calculate combinations on Casio fx-991ES plus?
SOURCE: mode change
Just so that we know what we are talking about. The natural display is the display mode in which fractions appear on two lines, radicals appear as radicals, log can be calculated in any base, etc. If that is what you understand by Natural Display, we are in agreement.
To set this mode, you turn calculator ON and press [SHIFT][MODE] (setup). The option is called MathIO, and it has the number 1.
Thus [SHIFT][MODE][1:MathIO].
Hope it helps.
SOURCE: Casio fx-7400G PLUS cubic solver?
First let us repair the terminology.
I am not sure that it has a solver (solving an equation or an inequation) but you can always draw your expression as a function and explore the graph (SKTCH) to locate the roots (or zeros) of the functions (the values of the variable where the function equals zero.) That is called solving graphically.
Hope it helps.
Thank you for using FixYa and for rating this solution.
SOURCE: how can we do linear interpolation in casio fx-991ES calculator
how solve interpolation by casio fx 991 ex
SOURCE: how can i calculate log inverse with my fx-991ES
By 'log inverse', you presumably mean the inverse of the logarithm function. There are two logarithm functions on most scientific calculators. Firstly [ln], or natural logarithms, to the base e, where the inverse is e^x. Secondly [log], or logarithms to the base 10, where the inverse is 10^x.
Example 1 : ln(2) = 0.69314718 so e^0.69314718 = 2
Example 2: log(2) = 0.301029995 so 10^0.30102995 = 2
To convert a single answer from symbolic to decimal, press the S--D key (just above the DEL key). To have all answers come out in decimal format, press SHIFT MODE 2 to switch to the LineIO mode.
