Question about Emglo KU Pump Valve Kit
I have a Hilti air compressorand it will not stop building preasure. How do I adjust it?
  • 749 Answers
The pressure regulator switch needs to be replace. This the little black box that your power cord comes out of. It screws into the compressor. You must remove the wires going to the electric motor. Then unscrew from compressor and replace with new regulator.
Posted on May 03, 2014
Anonymous
SOURCE:
Super silent air 20-air compressor not running it humms for 3 seconds an then turns off every say 10- 15 seconds.
Hi, does it build up preasure? Possible problems can be too much water in the tank, air intake pluged, auto shut-off not properly adjusted or defect. Was it run hot before without oil?
Oct 26, 2013 | Silentaire Technology Super Silent 20-A...
Pumping does not build preasure, every pump leaks out, help
If you take apart the pump mechanism you will see a little black o ring that has dried out either Reuben or replace and add a little oil to the mechanism to keep lubed and it will work fine.
Sep 30, 2013 | Daisy Model 840 Grizzly G Air Rifle Model...
Replaced al of the valves but still will not operate on high preasure. Will build to high preasure only for a couple of seconds then back to low preasure.
your bypass pressure valve is weak and needs replacing,its letting water pressure bypass the pump going to the pressure gun
Aug 05, 2010 | Northstar Pressure Washer 3000 PSI
I need a rebuild kit for a Hilti SN114B staple gun. Any idea where I might get one?
Yea, just called Hilti and they no longer make a kit for it. Hilti said you'd have to go a gasket and o ring shop to purchase similar parts individually. they quit making them in 1996
Feb 03, 2010 | Air Tools & Compressors
Does not build up air
check preasure release valve it may be sticking.
Dec 13, 2009 | Air Tools & Compressors
How to adjust the nailer, flooring is 5/8",so the cleats sit where it should be? How to avoid splitting the tongue on the wood?
You must put an in-line regulator at the inlet for the gun. Turn your preasure to 90 psi and use a sample board to get the fine tune adjustment at the gun. Turning down the air preasure will reduce the amount of force the anvil hits the nail with.
Nov 18, 2009 | Craftsman Nailer Kit, Palm Air Driver
Will hammer but not drill model te52
If it drills in the air but stops when you put it into concrete then the clutch is worn out. If it will not turn at all it could be stripped gears. Unfortunately Hilti no longer carries parts for that model.
Oct 01, 2009 | Hilti Drills
Clutch
I have had some problems with that as well. Two things that it might be one is air in the lines. Make sure that the air is properly bled from both valves. Start with the bottom first. The other if you have the 91 300zx that was made before August of 1991 then it might have the first Master Clutch Cylinder which has a smaller bore than the upgrade made by nissan in the later part of 1991. The upgraded CMC has a larger bore and works alot better with Aftermarket Clutch system.
Your problem seem to be that it doesn't get enough fluid to make preasure for the clutch. When DOT 3 fluid gets warm it expands but loose density which means it cant supply the preasure need to hold the clutch. Getting air out of the system which will block the line or increaseing the size of the bore on the CMC you can get more preasure which should improve the status of your clutch.
Oh yeah don't forget about the Pedal Adjustment. That sometime needs to bew done as well.
Oct 15, 2008 | 1991 Nissan 300ZX
Emglo KU Pump Valve Kit Logo
66 people viewed this question
Top Emglo Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Emglo Air Tool and Compressor Expert? Answer questions, earn points and help others
