Sharp XR-10X Multimedia Projector Logo
Posted on Jun 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No power sharp xr-10s... just died during a movie. No warnings. Will not power up, no lights. Dead as a nail. Would is at least power-up if bulb was dead?
  • richierudman Jun 22, 2009
    No fuse on the outside of unit.
    Could there be a fuse inside the unit under the area that looks like a miniture motherboard? I went as far as taking cover off, but did not go beyond removing boards.
    Because the warrenty expired last November, is there a cheap/trustworthy repair shop?
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Sep 08, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
2031
Points
10
There are six screws in the base and two in the back of the unit. After taking off the top I saw a red button on the front that was a little pushed out - I pushed it in and I got the led lights back :)
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 29, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
524
Points
I had the same thing happen to me, projector went completely dead while watching a movie.
there is a tiny red reset button/switch in front center of unit left of the lens. once i pressed it the projector worked fine again.
its hard to get to, i sort of pried the silver casing upward without taking it completely off, wasnt able to take it off all together, but randomly saw that reset switch while trying to lift of the silver top from front after removing all screws form bottom of unit.
Anonymous
Level 2:
  • Expert 58 Answers
  • Posted on Jun 22, 2009
Anonymous
Expert
Level 2:
Answers
58
Questions
0
Helped
44227
Points
164
Yes it would power up if the bulb was dead, but it may have a blown fuse, see if there is a removable fue on the back near the power cor, if so replace the fuse
  • Anonymous Jun 22, 2009
    Sorry you will need to find a repairer in your area
Sharp projector lamp will not come on
It is mother board problem.Reverse side of the board 5 pin ic not giving 12 volt.pin no. 1 input 12volt and pin no.3 12 volt out.it might be damage
Driver for projector
try av solutions in ny. they're a sharp service center. www.avsolutionsny.com
2answers
Projector turns on but does not illuminate bulb is good
may be either the colorwheel or the ballast. if you hear the colorwheel spin up (high-pitched whir), replace the ballast. if you don't hear it, replace the colorwheel.
My Sharp XR-40X DLP Projector bulb will not start. The bulb is not near the end of it's projected life nor did I get the "Replace Bulb" warning indicator. It has power and the fan comes on.
Hi Just be aware that the stated lamp projector specs "2000 hour lamp" does not mean you will get 2000 hours. What it means is that the lamp is rated to deliver up to 2000 hours. So some might get 1000 hrs, others 1593 hours etc.
The lamp may have died of its own accord prematurely and obviously unexpected.
With the power and fan coming on my first throughts are either the lamp or the lamp ballast (powers the lamp).
If you need a lamp we are able to supply replacement lamp delivered next time you need one, as we ship internationally and also the same with our revolutionary ICE Digital Daytime projection screens. Cost $US337 with lamp housing or lamp only $270. includes freight. Excludes any import taxes. http://www.youtube.com/watch?v=HvZ2DlVJ790 http://www.youtube.com/watch?v=qL_44xfK9y8 Regards Kevin Andreassend ICE AV Technology Ltd New Zealand http://www.digitaldaytime.com [email protected] +64-9-414 2348
1helpful
2answers
Sharp xr-10s /sharp xr 10sl are they the same unit?
Hey, XR10S and XR10SL is the same. The Lamp is SHP93 if for Replacement.
1helpful
Manual
http://www.sharp-world.com/products/data_projector/xgmb65xl/pdf/XGMB65XL_XR10XL_ex1_en.pdf
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
