Canon PowerShot SD600 Digital Camera Logo
A
Anonymous Posted on May 03, 2014
Canon sd780is manual - Canon PowerShot SD600 Digital Camera
2answers
How do i delete pictures on sd780is canon
Go to menu, select pictures, run though menu for pictures tell you see delete
All my recent pictures taken on my Canon SD780IS camera have a thin vertical line running down the right side of the photos. What is causing this and how do I fix it?
Hi if you also see the vertical line from computer, then your camera has defective ccd unit or main image control pcb defective. Most of case ccd problem are common and main. your local repair shop would charge around $45 to 135 depend on what they want to charge. Thanks and best regard!
8helpful
2answers
I have a Canon SD780IS camera and now notice dark spots on the pictures. I tried cleaning the front of the lens with a Q-tip but they did not go away or move around. I have 2 such cameras . One with 6-8...
to thansen 3:
Yes, eventually everyone who owns this camera will see these dust orbs in every photo they take once the problem appears, and the problem continues to worsen until you will see no image at all. I've had my SD780IS for about 2 years. I was very proud of what this camera could do until the dust appeared and discovered there seems to be no do-it-yourself solution. Canon will "fix" this under warranty.
When Canon returns your camera, it will no longer take sharp photos, but the dust orbs will be gone..... for a little while. Soon, we will all tire of sending these crappy, expensive little cameras back and forth to Canon. All of us will eventually toss this expensive junk and find another expensive Canon to use for about one year before we toss that one too.
The spots appear due to the complex external lens assembly which by its very function (moving in and out) invites particulate invasion. Canon deliberately allows us no recourse for practical maintenance outside of never using the camera. Why didn't I consider this before I purchased? Well, I trusted a corporation whose mission I thought was to provide durable high quality product. The plastic disposable film cameras of yore were an honest version of what we have purchased here.
You may notice a tiny hole on the ring surrounding the lens. My guess is the Canon techs insert a $.25 tool here which with some certain push and twist of the fingers will pop the lens assembly, exposing the CCD and rear lens element for cleaning. Effective reassembly may be another matter altogether as proven by the less sharp images I experienced upon return of the SD780IS from Canon. I have yet to locate any good solution addressing this difficulty. However, my wife still likes this camera despite her 20/950 vision. Some people are very easy to please. When she notices the spots, I'll look into getting her another camera.
1helpful
My Canon SD780IS beeps three times and then Lens Error, Restart Camera comes up. What can I do Camera is less than a year old.
This is a common problem if the camera has been dropped. Canon can take care of the problem if the camera is under warrenty
5helpful
Our Canon Powershot SD 780 is having a focus problem.
This might be a problem with the lens, I'm not exactly sure but I will get you in the right direction. There's a great site that just specializes in these Canon Powershot problems and they're terrific to say the least. If you go to camerasandparts.com you'll see your exact problem there for the canon powershot sd780is model. That should get you in the right direction to fix this problem. I really hope you can get help with this.
1helpful
I had my camera taking a video with and I dropped it, It automatically turned off but the lens didn't go back in. Now whenever I try to turn it on it says lens error and shuts off
The camera will need to be sent in for repair. Because of the age, you would be better served if you bought a new camera. For under $ 250 you can get the SD780IS which is smaller in size, has more pixels resolution and Image Stabization and many additional features you camera does not have.
I have a new Canon Powershot SD780IS. I took a movie with it, in multiple parts. The smaller segments will download from the camera to my PC very nicely, but the biggest (and most important) piece will...
Instead of downloading from the camera, try using a card reader to download it. The use of an inexpensive card reader is a much easier, faster, and less error prone way to download your photos and videos. In fact there are several important reasons discussed in this blog article link for using a card reader vice downloading from the camera. USB Card readers are also very inexpensive these day, with cost virtually not an issue.
E 18 problem
if it is E18 error u might get help from HERE
or it might be a CCD FAILURE kindly call canon they will do it FREE
dont worry call them see this for info on this problem
KINDLY RATE ME WELL !
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
