Dell Vostro 1088 Logo
A
Anonymous Posted on May 02, 2014
Nam_led and cap led error - Dell Vostro 1088
Ban co biet ceo cua bkhost la ai khong
Mr Thanh la CEO cua BKHOST Viet Nam ong chiu trach nhiem ve dinh huong cung nhu chien luoc cho su phat trien thuong hieu cua BKHOST Viet Nam
Quyet liet va dam me voi cong nghe thong tin Mr Thanh luon la nguoi tien phong dua toi nhung san pham cong nghe thong tin moi nhat den Quy vi
Mr Thanh co nang luc lanh dao tinh than kinh doanh va san sang chap nhan rui ro cao giup BKHOST Viet Nam se tro thanh mot trong nhung nha cung cap dich vu tren internet uy tin va tin cay tai Viet Nam
Hien nay ong cung dang dam nhan chuc giam doc cua cong ty
neu ban muon tim hieu them thong tin thi co the tham khao trang nay https bkhost vn pages about cua BKhost
tip
Laptop LED Blink on Startup There are many reasons that a computer does not...
There are many reasons that a computer does not startup or boot into the Windows operating system. If your computer will not start or boot, you will see or hear symptom to indicate the general area of the problem.
Startup Symptom: LEDs blink but does not start
The blinking LED lights on newer computers, or the beep tones on older computers, will help support agent determine what hardware component is not responding properly. The exact meaning of each code varies with the model, and the user cannot change any of the blink or beep codes.
DO THESE FIRST - Perform a hard reset.
If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
2. Disconnect the AC power adapter, remove the battery and then press and hold the power button for at least 15 seconds.
3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Identify the number of blinks or beeps
When there is a start-up problem and you see LED lights on the keyboard blink a few times (between 1 and 8 blinks) do the following actions.
Table of Sample Blink Codes
The following table illustrates the meaning of blink codes used on some notebooks. The blink or beep codes on your computer may have different meanings.
Meaning of Sample Blink Codes for some EFI Notebooks:
1) Number of Blink: Continuous Glow, Blinking LED: Battery power LED, Component: Battery,
Error Condition: The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.
2) Number of Blink: 1, Blinking LED: Caps Lock/Num Lock, Component: CPU,
Error Condition: CPU not functional
3) Number of Blink: 2, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS corruption failure
4) Number of Blink: 3, Blinking LED: Caps Lock/Num Lock, Component: Memory,
Error Condition: Module error not functional
5) Number of Blink: 4, Blinking LED: Caps Lock/Num Lock, Component: Graphics,
Error Condition: Graphics controller not functional.
6) Number of Blink: 5, Blinking LED: Caps Lock/Num Lock, Component: system board,
Error Condition: General system board failure.
7) Number of Blink: 6, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS authentication failure.
8) Number of Blink: Continuous blink, Blinking LED: AC power adapter LED, Component: Power adapter,
Error Condition: Insufficient power
Common solutions for issues that cause blinking LEDs or beep tones
When the computer can boot into the BIOS, run the memory test to identify other issues.
Check for loose connections and test the memory
Blink codes are often displayed after a user adds memory to the computer but does not seat the module properly. The LEDs may also blink error codes if a hardware component is loose because the computer was dropped or jarred. The problem could be that the stick of memory or one of the memory slots has a bad connection.
Check for loose memory modules
If a memory module is loose or is not making good contact with the memory slots, the computer does not recognize all of the memory. Reseating the memory module may resolve memory failure errors.
on Mar 21, 2011 • Computers & Internet
5helpful
3answers
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
On My Dv5-1125nr both the caps lock and num lock keeps blinking when i turn it on. It's wont boot at all. What kind of hardware problem is this?
First remove the battery and power cord for about a minute. Then plug back in and see if that helps. Otherwise please read the following:
The capslock and the numlock leds r flashing continously. the screen is blank
How many blinks between pauses if there are pauses? Look at this chart.
Number of Blinks or Beeps Location of Blinking LEDs Component Being Checked Error Condition Continuous glow Battery power LED Battery The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook. 1 Caps Lock/Num Lock CPU CPU not functional 2 Caps Lock/Num Lock BIOS BIOS corruption failure 3 Caps Lock/Num Lock Memory Module error not functional 4 Caps Lock/Num Lock Graphics Graphics controller not functional 5 Caps Lock/Num Lock System board General system board failure 6 Caps Lock/Num Lock BIOS BIOS authentication failure Continuous blink AC power adapter LED Power adapter Insufficient power
4helpful
Why the caps lock and scroll light keep on blinking without entering to the window
The lock leds are used by some computer manufacturers as an error indicator. if you are unable to boot up and the lock LED's for caps and scroll are constantly flashing then it would indicate that your computer has most likely encountered a hardware error preventing it from loading. if you can add a comment with the manufacturer and model of your computer I can help you check the error
I changed from NAM 1 to NAM 2. and lost unlock code
Try this URL : http://www.blurtit.com/q1652331.html
I have a Samsung U520 and I accidentally activated NAM2. Now my phone does not work. When I try to deactivate NAM2 it asks for a password. Can you help? It needs a 4 digit code. It also states Initial...
hi sir have you done restore factory settings firstThe Nokia 2160 series hand portable CMT uses an EEPROM NAM that can be programmed directly from the standard user keypad. In order to access the
NAM, you must enter the special access code currently programmed into the
phone. Once the programming mode is accessed, NAM parameters are loaded
by entering them into the display and "storing" them to selected memory
locations. Be sure to obtain all parameters before proceeding.
EASY NAM PROGRAMMING
1. Turn on phone.
2. Enter the Easy NAM access code. Access code is: *#639#
3. Verify the display now reads "Cellular Number" and enter the 10 digit
MIN for the phone.
4. Press the softkey under the word "OK" in the display. If less than 10
digits are entered an error message will prompt you to reenter the
number.
5. Verify the display reads "Enter code" and enter the five digit SID
followed by four zeros. (Example 001750000 is a SID of 175 followed
by four zeros). An error message will display if an incorrect entry
is made. Do not add more than four zeros to the code.
Note: Change the Lock code by adding a pound sign and new lock code after
the code. (Example: 001750000#7788. Lock code = 7788).
Change the Language code by adding a pound sign (#) and new
language code after the code. (Example: 001750000#2. Language = 2)
Language Code: 0 (default) = English, 1 = French, 2 = Spanish,
3 = Portuguese
Change the Lock code and Language code by separating each set of
numbers by a pound sign. (Example: 001750000#7788#2). The SID =
00175, Lock code = 7788, Language = 2 (Spanish).
6. Press the softkey under the word "OK" in the display.
7. The display will tell you t
Mitsubishi WD-62525 Red Status Light After Cap Replacement
which caps did you replace? As the normal repair for the first generation dlp is to replace the (4) 1000 uf caps. the (2) 2200 uf caps and the (2) 3300uf caps on the power pwb when you get the 34 error code.
1helpful
My daughter was messing around with the NAM settings switehed it fro NAM 1 to NAM 2 then the phone restarted and when it turned on it asked fro a lock code nothing she or I entered worked and it displays a...
The NAM is the internal cellphone number...every phone has 2 numbers...the one you use, and the one thats used to identify it... press *228 and then switch the NAM back to NAM 1
if that doesnt work take it back to your provider and they can reprogram it....however any contacts you had saved or music, pics, videos or downloads are gone for good...sorry
Apr 24, 2008 • Cell Phones
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
