Winter Sports Logo
A
Anonymous Posted on May 02, 2014
Ignition wont work on a vk professional - VK Professional Yamaha Winter Sports
gentech5
Level 1:
New Friend:
Problem Solver:
  • Contributor 18 Answers
  • Posted on Oct 11, 2014
gentech5
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
18
Questions
0
Helped
8896
Points
21
Check your fuses. use a ohm meter.
use a test light to see if you have power to your ignition switch.
if not check your relays.
if you have power to your switch turn it to the on position, see if you have power there. If you have power there, then turn it to the start position,see if there is power there. if not replace switch.
Hope this helps.
2007 vk professional running hot,engine light on,codes 21,84 on
I have the book but I cant find the codes.
So find out if your rad fan is coming on. If it does then pull out your thermostat and place it in a pot of water and see at what temp it opens at. The open temp should be stamped on the thermostat.
If it is stuck closed or opening to slow, replace stat.
Running hot
I need a bit more info.
What is the strength of your coolant?
Does your rad fan come on?
When, and what type of conditions does this happen?
Where do you add gear oil on a 2006 yamaha vk pro
There should be a dip stick on the chain case remove it and add oil there. until it is full on the shight glass.
Hope this helps.
Yamaha manual
What info would you like on the chain case?
How to adjust gear chain on Yamaha VK pro
Locate chain tension bolt.
Loosen locknut.
With 2 fingers tighten the lock bolt until it is tight.(not crazy tight)
Then back off the lock bolt 1/4 of a turn.
Hold bolt and tighten lock nut.
You are done now.
I can't access the DVD features on my Westinghouse vk-40f580d, I put the dvd in and go to the DVD menu, but wont let me use any dvd controlls, it wont on the remote and tv buttons, AND I cant eject, please...
to eject the disc, turn off your TV and hold the eject button then power TV back on. Regarding the DVD feature not working, you may need to change the main board. If your TV is still in warranty, call 1-800-701-0680 for an in home service.
Top Yamaha Winter Sports Experts
Arnie Burke
Arnie Burke
Bob G
Sean Wright
Sean Wright
Are you a Yamaha Winter Sport Expert? Answer questions, earn points and help others
