Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
SOURCE: MY TV NEEDS ANTENA
Any antenna with a 75 Ohm impedance RF coax in or out, or a 50 year old set of rabbit ears with tin foil and a 300 - 75 Ohm transformer (adapter) will work. There are many new ones to chose from and they will go right in line with the cable from the wall (basic) or your converter box, or you can splice it in with an impedance matching splitter. The powered ones with active filters are nice. You can find them in the RECYCLE bins up and down the street this week
SOURCE: I have a panasonic viera tc-p50s1 and I can't get
The power supply board have problems,it not giving the right voltage to the tv anymore.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbush power supply board for the replacement.
Testimonial: "Great Help with trying to get my tv back up and running."
SOURCE: Panasonic Viera tc-32lx85 trouble code 3 blinks
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help in solving the problem.....
SOURCE: Panasonic VIERA TC-L32C3 32-Inch 720p LCD HDTV
Hello, welcome to Fixya!
You didn't state any problem concerning this TV. What precisely is the problem with your Panasonic VIERA TC-L32C3 32-Inch 720p LCD HDT?
I look forward to your reply.
Regards.
SOURCE: Panasonic viera will not turn on
Try the following troubleshooting steps.Check power cord and power outlet, possible light switch problem.
Check if you TV savy check the P board if the P board is not good check the fuses on the P board.
If the P board is OK check the A board.
To check these Unplug the TV , Disconect A5 A6 and A7 on the A board and plug the TV in and see if you get a white screen if this is the case your P board should be OK.
