I checked for leaks and couldn't find any
If the drive motor is running and you haven't got leaks then it is the compressor itself or the connection to it which is faulty. If the motor is working it doesn't mean the piston in the compressor is going up and down. There are various valves within the compressor that can either break or jam open and these can prevent a pressure build up.
I think this is one of those problems you need to have in front of you as there could be many failure reasons, some not good and others fairly easy to get resolved.
You need to strip the compressor down to find the fault and then assess if it is a repair or new compressor.
