LG WM-2277HW Front Load Washer Logo
D
Dawn Posted on May 02, 2014
Washer has code FE - LG WM-2277HW Front Load Washer
Why on an LG Front loader does the FE code come on and not on Rinse & Spin?
Here is the LG site for washing machine error codes, you can scroll down and find the FE code there:
http://www.lg.com/us/support/product-help/CT10000010-20150140270078-other-error-codes
The site shows the following:
The FE error code indicates the washer is overfilling. This is usually the result of a faulty water valve.
1. Close both water taps.
2. In order to drain out any trapped water, power the washer back on and press the Spin Speed button until No Spin is selected and press the Start/Pause button.
3. Once the washer has drained, restart the wash cycle.
2answers
FE code on LG washer.
The FE code is an excessive water supply if the water is continuously running into the machine it may be due to a failing inlet valve or stuck float switch since you mentioned the drain pump filter being changed it could be that the old filter was restricting the flow.
On my LG tromm washer has an error code FE, what is the solution to this problem or how do i get it fix???
The FE error or fault code indicates that the washer is overfilling due to a defective water inlet valve. The valve is not repairable and will need to be replaced.
How do i reset FE code on wm2016cw washer machine
Oct 16, 2014 • LG WM2016C
2answers
Code fe on lg what does this mean
This fe error or fault code indicates that the washer is overfilling due to a defective water inlet valve. The valve is not repairable and will need to be replaced.
2answers
LG front load washer is leaking underneath the front left corner, the display code is FE.
Why don't you simply find out what the FE code is alluding to? Go to web site or do a google search and then you can check for the issue further.
What does FE code mean?
KENMORE TOP LOAD WASHER WITH FE CODE WHAT DOES THAT MEAN?
2answers
In display shown FE
"FE" error code - over flow error
-Check water conection
-Check Water valve for proper operation
When the "FE" error code is displayed the drain pump will be turned on to pump the water out of the washing machine. LG Washing Machine Error Codes
This error code comes up when there is a over flow condition. The error is coming up because a part inside the washer has failed. I suspect the water valve on the back may be the culprit, it's fairly common.
Hope helps.
3helpful
LG front load washing machine WM2233H Error code is FE
I found this information on the internet. I hope that it helps.
" Getting fe code on lg washer.
"This means that the washer is overflowing. This is a built in fault that turns on the drain pump so that the water doesn't get so high that it gets into the floor. If water is continually flowing into the washer you will get this problem. If this is the case the water valve is most likely the problem. To confirm unplug the washer and if the water doesn't stop flowing into the washer the water valve is the problem.
Thank you,
Shawn"
I hope that this helps you out
2helpful
Error code FE
From the manual ,FE means Water level is too high due to a faulty water valve. hence the possible leak
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
