I am not sure if the drum needs replacing or if it is a fault, but every page has black horizontal lines all down the right-hand side, and the text it prints is very faint on the right side too. The rest of the page looks fine.
SOURCE: Printing on half page only
you need to clean laser but first try to change drum and toner
elvis
SOURCE: grey stripe on printed page
Hi please follow these small steps:
For complete information with pictures click on this link.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000012/faq000212_012.html?reg=us&c=us&lang=en&prod=hl1440_all&Cat=3
Cheers
Please Let me know if it worked for you or not
SOURCE: Lines on Paper
Under the drum there is a thin ****-glass. Make sure there is nothing on the glass. Do not use compressed air to remove the debris from the glass. Use a dust cloth or such. Using air will blow the debris into the laser unit and it will have to be taken apart to be cleaned.
SOURCE: Black line down the paper on copy mode. Ok in print mode.
There is most likely something on your scan glass that is blocking the scanner. Clean of both pieces of glass that are there when you flip open the ADF, or top cover. Try to copy again. If it is still there then there is either something on the scanner piece that moves back and forth to scan or one of your scan LEDs is burnt out and the scanner will have to be replaced.
