Canon DR-5010C Scanner Logo
A
Anonymous Posted on May 01, 2014
Canon dr - 5010 no driver - Canon DR-5010C Scanner
2 Related Answers
mohanchennai
Mohan Sriraman
  • 490 Answers
  • Posted on Sep 25, 2008
SOURCE: drivers for Canon DR 3080C
You can get them from the following site
http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2341&modelid=512
S. Mohan, Chennai
Anonymous
  • Posted on Feb 25, 2011
SOURCE: ERROR MESSAGE lamp was over Canon DR-1210C driver
lamp was over Canon DR-1210C driver verion 1.01.10601.23003(-4430)
Scanner parameter in correct 4408 canon dr 5010
Please restate your answer in the form of a question.
I have a canon dr 5020 that just started scanning slowly
Check if there is enough disk space in the comp target area. Run defrag and scandisk.
S. Mohan, india
49helpful
3answers
Error code 5010
Canon only lists three 4-digit error codes for the MP500: 1700, 1851, and 1856. After much research and finding many other MP500 owners getting this same strange code, I have come to conclude that it's the code of DEATH. Sometimes you may get strange codes if using compatible ink cartridges. Unless you can get the printer to reset and clear, the only other thing to try is to go back to the Canon driver download page and reload the correct driver: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=11995
Always have to rotate to 270 is this normal. I have to five copies and thet all have to be rotated
The Canon 5010/5020/9080c/7580C etd are duplex scanner (can scan both sides in one go). If you select simplex i.e., only top side, you will get the image straight, unless you have changed the settings in the scanning software. I am assuming you are using CapturePerfect software. Please switch off the rotate option in Capture perfect and the scanner output will be as you see it.
S. Mohan
2answers
Keeps coming up with error 5010
Hi
Thanks for using FixYa. To reset the Printer turn it off and remove the power plug from the outlet. About fifteen minutes later, plug it in again and turn the printer on. If still the issue the printer is facing with persists, then you need to follow these steps as the 5010 error relates to the drivers and you need to download the latest drivers compatible with operating system and model of printer.
Uninstall any previous drivers for the printer and to install the printer, unplug the printer completely, restart your computer. Install the drivers using the file you downloaded from canon, do not attach the printer to the computer, or power on until you are told to do so. You can download the drivers from the following link of Canon---
Printer Drivers for Canon Pixma MP460
Please do rate the solution and revert for further assistance.
Thanks
Rylee
2answers
My MP160 Printer is plagued with problem Service Error 5010. Neither I can print nor scan. Please help me to fix the problem.
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ppobmi20
4helpful
4answers
To get ride of Canon Pixma MP160 Service error 5010.........!!!
Pliz help me out and fix the service error 5010 which i get as soon as i turn on my printer and due to which the alarm light starts blinking, i'm helpless coz either my printer or Scanner isn't working, so pliz stretch out your helping hand in order to let me get ride of this.
Regards,
PRINTER DOT COM
6helpful
2answers
old marine
old marine
ZJ Limited
ZJ Limited
