Question about Technics SL-DZ1200 CD Player
Where is the input of coin slot remote diagram?
I want to know the input and the power capacity and functions of the wires of the accessory remote?
What does bmc mean and what is it for on 1 2001 buick lesabre
BCM - body control module a computer that controls functions on your vehicle . A BCM controls light's , power door lock's , anti-theft system control , Remote keyless entry , headlamps . On your vehicle three modules make up the body control system .
The body control system consists of the following 3 modules:
• The dash integration module (DIM)
• The instrument panel integration module (IPM)
• The rear integration module (RIM)
Each of the 3 body control modules integrate a number of functional systems under the control of a single module. Each of the modules are connected to the Class 2 serial data line; many control signals are implemented by Class 2 messages.
Dash Integration Module (DIM)
The DIM is wired to the class 2 serial data line. The various DIM input and output circuits are described in the corresponding functional areas as indicated on the DIM electrical schematics.
The DIM functions include the following:
• Control of headlights and exterior lamps
• Horn relay control
• Interior lamps incandescent dimming
• Lamps On signal with wiper/washer
• Power moding control over Class 2 serial data line
• Steering wheel controls
• Storage of the clock settings and, sending a message out on the class 2 serial data circuit in response to requests from other modules
Serial Data Power Mode
On vehicles that have several control modules connected by serial data circuits, one module is the power mode master (PMM). On this vehicle the PMM is the DIM. The PMM receives 4 signals from the ignition switch.
To determine the correct power mode the PMM uses the following circuits:
• Accessory voltage
• Ignition 1 voltage
• Ignition 3 voltage
• Off/Run/Crank voltage
Rear Integration Module (RIM)
The RIM is wired to the class 2 serial data line. The various RIM input and output circuits are described in the corresponding functional areas as indicated on the RIM electrical schematics.
The RIM functions include the following:
• The ajar switch and tamper switch inputs from the rear compartment lid
• The automatic level control
• The cigar lighter relay control
• The fuel door lock and release control
• The heated seat controls
• The park brake relay control
• The rear compartment lid release controls
• The rear defogger relay control
• The retained accessory power (RAP) relay control
• The reverse lamp relay control
• The various controls for the interior lamps
Mar 21, 2017 | Buick LeSabre Cars & Trucks
1998 buick regal stereo what are the wire color codes
showgif.do?image=73222
Connector Part Information
12110115
32-Way F Micro-Pack 100 Series (Blue)
Pin
Wire Color
Circuit No.
Function
E1
DK GRN
835
Entertainment and Comfort (E&C) Serial Data Communication
E2-E5
Not Used
E6
DK BLU
1796
Steering Wheel Controls Input
E7-E8
Not Used
E9
LT BLU
1405
Remote CD Changer Common Input
E10
ORN/ BLK
1406
Remote CD Changer Left Channel Input
E11
LT GRN
1407
Remote CD Changer Right Channel Input
E12
BRN
199
Speaker Feed-Left Rear
E13
YEL
116
Speaker Return-Left Rear
E14
DK GRN
117
Speaker Return-Right Front
E15
LT GRN
200
Speaker Feed-Right Front
E16
BLK/ WHT
351
Ground
F1
ORN
640
Fused Battery Feed
F2
YEL
43
Fused (Retained w/KP2) Accessory Power Feed
F3
DK GRN
145
Radio Switched Power
F4
GRY
8
Interior Lamp Dim Switch
F5
YEL
32
Fused Interior Lamp Dim Signal
F6-F10
Not Used
F11
BARE
2011
Remote CD Changer Drain
F12
TAN
201
Speaker Feed-Left Front
F13
GRY
118
Speaker Return-Left Front
F14
LT BLU
115
Speaker Return-Right Rear
F15
DK BLU
46
Speaker Feed-Right Rear
F16
Not Used
Dec 20, 2014 | 1998 Buick Regal
HOW DO I CONNECT A AN EZPRO 610 PROJECTOR TO A LAPTOP COMPUTER.
1. You will need a VGA or S-video cable and a 1/4 inch stereo plug that will go from the earphone jack to the EZpro then out to a amplified system for the sound.
2. I believe the EZpro has connections for HDMI which will supply sound as well as High definition video. You should have an adapter for the HDMI also if you
3. connections port as follows:
1. USB Connector (Connect to PC for Remote Mouse function)
2. RS-232 Connector
3. Audio Input Connector
4. S-Video Input Connector
5. DVI-I Input Connector
(PC Digital (HDCP)/PC Analog/Component Video Input)
6. VGA In/SCART Connector (PC Analog Signal/Component
Video Input, HDTV/SCART Input)
7. VGA Output Connector (Monitor Loop-through Output)
8. Power Socket
9. KensingtonTM Lock Port
Looking at the usb port go counter clockwise the numbers are in succession. 1- 9
1 Power Cord
2 VGA Cable
3 DVI-I to VGA Cable (Optional accessories)
4 Audio Input Cable (Optional accessories)
5 RS232 Cable (Optional accessories)
6 USB Cable (Optional accessories
Apr 24, 2010 | CTX Optoma EzPro 610 Multimedia Projector
The CD Player I'm installing in my Accent says to connect one of the wires to an accessory terminal in the fuse block, Can this accessory be the power antenna?, the one with the pink wire? Regards and...
No - this is the positive key power input. Connect to the input power that was connected to your old CD tuner.
The antenna wiring will be separate. You will also have a battery power input. The battery power input will provide continuous power so that your presets don't get forgotten and your CD will play from the same place when you turn your car on and off. The accessory or key power lets your CD player know that you've turned your car on and it should also wake up.
Hope this helps, Sherwin
Jan 02, 2010 | 2001 Hyundai Accent
I have a kenwood kdc 233 cd player in my car but the remote wire aint working because i tried hooking up an amp i pit a light power tester on the remote wire but dont work and i dont think the input plugs...
as far as the remote wire a keyed power wire from under dash can be used its the same thing.if the remote wire is working it wont turn on your amp so are you sure thats not why your rcas dont work or have u hooked power to the remote on the amp.
Nov 09, 2009 | Car Audio & Video
Don't know how to install equalizer. Where does
hi input wiring hooks up to speaker wire outputs on the stereo. in 2008 chrysler has no ignition or accessory outputs. everything is digital, if you use a trunkloc from PAC electronics you will be able to hookup your outputs from the deck into this unit and it will provide you with the RCA, and remote power output needed for your system to operate. the factory deck should have battery and ground at the plug but no acc.
Sep 23, 2009 | Soundstream XTA720.4 Car Audio Amplifier
I'm looking for a wiring diagram for a Clarion drx5675 does anyone know where i can find one? Or can someone give me the color coding to the wiring so i know where they go to, thx
Clarion uses the industry standard wiring colors. Not every unit will have all of the listed wires
SPEAKERS:
White = Left Front +
White/Black = Left Front –
Gray = Right Front +
Gray/Black = Right Front –
Green = Left Rear +
Green/Black = Left Rear-
Violet = Right Rear +
Violet/Black = Right Rear –
POWER/ACCESSORY:
Yellow 14ga = Battery Main/Memory
Yellow 18ga = Battery CeNET Power/Memory
Red = Accessory (ignition on)
Black = Ground
Blue = Antenna Turn On +
Blue/White = Remote Turn On (amps) +
Orange/White = Dimmer
Brown = Phone Mute
Orange or Mint Green= Parking Brake Video Lockout
White/Red = CCD (camera) input instant on +
RCA Cables:
Gray = Front Output
Black = Rear Output
Purple = Non-Fade or Subwoofer Output
Feb 21, 2009 | Clarion RAB250D
Mintek dvd player, model mdp-1030
Mintek MDP-1030 DVD Player Description:Mintek is one the largest suppliers of DVD players in the global marketplace today. Mintek has taken the next natural step in the evolution of the company's product line combining leading DVD technology with state-of-the-art LCD technology.PRODUCT FEATURES:
Versatile playback formats;
Anti-shock function - mobile or pedestrian;
Built-in stereo speakers;
Auto power off for saving energy;
Quick connect to TV;
Digital Coaxial Output;
AV input/output;
Brightness/Color/Display mode adjustment;
High capacity rechargeable Lithium-ion battery pack;
Full function remote control.
Product Specification: DVD Player DVD Type DVD player Media Supported Kodak Picture CD, CD Portable Yes Form Factor Portable Remote Control Remote control Additional Features Auto power off Audio Features Audio Output Stereo MP3 Support Yes Connectors Composite Video Outputs 2 x headphones ( mini-phone stereo 3.5 mm ) 1 x digital audio output (coaxial) 1 x composite video/audio input 1 x composite video/audio output Power Battery Type 1 x DVD player battery - rechargeable - lithium ion General Product Info Weight 4.6 lbs Also known as Mintek MDP-1030, Mintek Manufacturer Part No. MDP-1030 Company Info Mintek Dimension 1.6 in x 10.1 in x 6.6 in (HxWxD) Model DBMDP-1030
Aug 17, 2008 | Compaq Presario Notebook
No power
You have the wrong wire hooked up to the 'remote' input on the amp. The remote input waits for a discrete 12v+ signal from the radio. You have the 'power antenna' wire hooked up to the remote input. The power antenna lead shows 12v+ when the radio is on, but as soon as you change the source to CD, the power antenna drops the 12v+ and shuts your amp off. If you're radio has a blue/white wire, use that to turn the amp on instead of the blue wire you are currently using. If there is no blue/white wire, either the radio uses a non-standard color or the radio does not have the necessary wire. In the case that there is no true 'remote' wire, you can get away with using the accessory wire to the radio. That would be the red one. Jump that one over and you'll be running.
May 11, 2008 | Clarion APA2160 Car Audio Amplifier
Accessories
i can send to u manual n remote by post or corrier service.
model no.
capacity of a/c
brand name.
which remote. wireless or with wire.
send details to mintex007@yahoo.com.mobile no 09954408007
Mar 11, 2008 | Heating & Cooling
Technics SL-DZ1200 CD Player Logo
56 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
