Question about Samsung TL34HD / NV100HD Digital Camera
My samsung NV100HD camera does not come on, how do i reset it
2 Suggested Answers
6ya staff
SOURCE:
Andy
  • 262 Answers
SOURCE: my samsung NV100HD camera is
You can probably tell that this is a 'standard answer' that I wrote a little while ago, but to be honest with you, it's a 'standard question' that gets asked a lot! I'm pretty sure Samsung cameras like your NV100HD use SD cards, so it applies to you:
Why does my camera say "Card Locked" or "Write Protected"?
The basics. In the same way that the recordings on audio cassettes and VHS tapes could be protected by breaking off the little tab on the back corner, the material on a memory card can be protected against being overwritten. Instead of a tab to break off, write protection is done by a tiny slider on the edge of the card (opposite the cut corner). Before the camera will take pictures, it's necessary that this slider on the card operates a microswitch in the camera, which it will only do if it's NOT in the 'lock' position. The slider actually does nothing inside the card, which is why I don't call it a 'switch' even though it seems like one. Its only purpose is to be detected by the microswitch in the camera's slot, and it's the camera that takes care of the write protection, not the card.
Diagnosis.
Obviously the first thing to do is to check that the slider is NOT in the lock position. If the camera is giving you this error in the unlock position, it means that the slider has failed to operate the microswitch, or that the microswitch itself is faulty, or possibly that there's some file system error with the card. To diganose the problem, it would be really helpful if you could try two or more different memory cards in the camera and see if just one, or all of them exhibit the problem.
If only one memory card exhibits the problem: In this case, it's clearly something to do with the memory card. Is the slider worn, bent or missing? A missing slider will write protect the card in the same way that sliding it to the 'lock' position will. There's another possibility. I've recently discovered that
some cameras which use xD-Picture cards also give this error even though those cards don't even have lock sliders! Furthermore, some users have reported fixing this error by reformatting the card. Therefore, I feel it's also possible that your error may be fixed by reformatting. Before you do this, make sure that you've copied all you want off the card and then use the camera's 'format' function to reformat the card. I advise using the camera for the format function because this guarantees the correct file system. If you use your computer to format it, you may easily get the wrong one. However if you need to do it this way, see which file system is currently in use on the drive before you start. Go to "My Computer" and right click on the drive which is the memory card, and choose "Properties". Examples of filesystems are "FAT" (probably FAT16), "FAT32" and NTFS; to make sure your reformat is successful, ensure you use the same filesystem as before.
If some memory cards work, and others don't, or the same cards sometimes work but only sometimes:
The slider is really tiny, so it's possible that the number of people reporting this error is caused by lack of precision in manufacturing sizes. It must be hard to make a microswitch that can feel such a small thing. Does a better brand of card work? Can you bear to simply stick to the better brands, or the ones that work most reliably? As a remedy of last resort, you could try wrapping a small strip of sticky tape over the slider to increase its thickness, but I think this is a risky solution. There's a risk that the tape will come off in the slot and cause even more problems, or that the tape will be so thick that the card will jam in the slot and you'll have trouble getting it out.
If all of your memory cards behave in the same way: In this case, it's clearly something to do with the camera. It could be that the microswitch is broken, or there's some software error. Although it's less likely, let's cover the software error first; please find the 'system reset' function in your settings menu and use it to clear everything. Any good? If not, try the sticky tape solution in the last paragraph in the hope that it's a size/fit problem with operating the microswitch, but if that fails we're out of options really, beyond a repair of that microswitch.
Posted on Feb 01, 2011
Nv100hd
It still could be the batteries, unfortuneately the only way to find out is replace them.
Mar 22, 2012 | Samsung TL34HD / NV100HD Digital Camera
Drivers for NV100HD camera
Consider NOT using a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Dec 24, 2010 | Samsung TL34HD / NV100HD Digital Camera
There is particles in the lens that are showing up on the images as orbs.
Do these "soap bubble" like orbs only appear in flash pictures and in different places each time? If so, they are dust particles reflecting the flash back into the lens. We all have this problem.
Oct 25, 2010 | Samsung Digimax NV100HD Digital Camera
Lens stuck out
Location which may have damaged. Please visit service center.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Feb 01, 2010 | Samsung TL34HD / NV100HD Digital Camera
Camera wont let lense come out
notify SAMSUNG of your problem should have warranty
Nov 18, 2017 | Samsung TL34HD / NV100HD Digital Camera
My computer running XP Media edition 2005 won't recognise my nv100hd camera. My other computer running xp home will. I have tried uninstalling usb drivers and a new lead. The two items just will not see...
Hi there. Try this.
Turn your computer off. Unplug the camera from the computer.
Restart your computer. Make sure the camera is off and when you have rebooted, connect the usb cable to the computer. Make sure your not using a usb hub.
Turn your camera on and go to my computer. See if it's listed in your drives.
Let me know if this helps with a comment. If it does help, feel free to rate my answer, and thanks for coming to FixYa.
Rob
Feb 22, 2009 | Samsung TL34HD / NV100HD Digital Camera
Samsung TL34HD / NV100HD Digital Camera Logo
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
