Question about Technics SA-AX540 Receiver
My amplifier mdel is a-ax540 how can iget ,output i.c RSN- 313H25 AND RSN310R36
AMPLIFIER MODEL SA A X540
6ya staff
SOURCE:
ABRsvcs
  • 4234 Answers
SOURCE: Hi there .......my sa gx303P
These units are designed to only run the fan when necessary. If the unit is overheating, there is a problem in the detection circuit. This is a relatively inexpensive repair. If you are getting overheating when running at a low volume, it suggests that the speakers are not matched to the amp. In other words, the amp is expecting an 8 ohm load and is being presented a lower ohm load. This makes the amp work harder and generates more heat. Check the speaker wires and make sure that they are not frayed or crossing in any manner. Also, verify that the rating of the speakers is correct.
Update this with what you find.
Thanks,
Dan
Posted on Dec 02, 2008
ABRsvcs
  • 4234 Answers
SOURCE: Technics SA-AX540 Receiver
It is unlikely that the display itself is faulty although it can happen. The typical problem is either the backlight is defective or the suply to the unit has a bad connection. If you can solder, try resoldering the pins on the display itself. The pins on the ends are the power and ground. I don't recall whether or not your model has a separate back light bulb or not. That too could be burned. Chack for that too.
Keep us posted,
Dan
Posted on Mar 02, 2009
SOURCE: Ipod Connection
Here's a link with a lot of discussion on how to do that.
Charlie
http://forums.ilounge.com/archive/index.php/t-37576.html
Posted on Oct 01, 2009
Francis-LE4
SOURCE: technics tuner amplifier sa-eh750
I want to change the language on technics hi fi sa/eh750 to english
Posted on Jun 01, 2010
SOURCE: when I turn on my technics sa-gx amplifier I can't
Have you noticed if the speakers selector switch in the front panel is set to off ? That position for the switch is only suited to listen heaphones. Good Luck.
Flavio/BRAZIL
Posted on Jul 28, 2010
WANT TO GET OUTPUT I.C FOR STEREO AMPLIFIER TECHNICS MODEL SA-AX540
Try Ebay or Audio Lab of Ga.
If it's a single module , it wont be cheap
May 01, 2014 | Technics SA-EX500 Receiver
My Technics SA-AX540 AV Control Stereo Receiver keeps shutting off and on and displays overload. Does anyone have a fix for this problem?
Heat?
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections as a root cause for intermittent shutdown.
Feb 21, 2011 | Technics SA-AX540 Receiver
Same problem
The overload indication tells us that there is a problem in the final stage of the amplifier section. This model uses an AMP-PAC or large amplifier IC (part number RSN-3305) which is now defective. If you can solder, try resoldering the pins on this IC. Sometimes a poor solder connection can cause a voltage offset that will be detected as a fault and shutdown the system like this. If the resoldering fails, the IC will need to be replaced. Parts cost will be in the $75-$95 range.
Dan
Sep 14, 2009 | Technics SA-AX720 Receiver
Su-g91
Have you checked the fuse in the unit?
Aug 31, 2008 | Technics SA-AX540 Receiver
Panasonic sa ht530
REPLACE RSN IC(SOUND AMPLIFIER THEN CHECK AND REPLACE 2 -3 SMALL TRANSISTORS TWO 2SC3199 AND ONE 2SD592 THEY RE ON THE AMPLIFIER BOARD,EVEN WHEN RSN IC IS REMOVED SHOULD NOT SHOW F61 AFTER YOU'VE REPLACED THOSE TRANSISTORS
Mar 21, 2008 | Panasonic SC-HT730 System
Hook up pioneer stereo amplifier model SA-1270
for audio system always you have left and right channels.
get the output (left&right) from tuner---go to equalizer input left&right.---from equalizer output go to amplifier inputs.and certainly from amplifier output to speaker.
Oct 15, 2007 | Audio Players & Recorders
Technics SA-AX540 Receiver Logo
89 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
