SOURCE: sc 542-00 trouble code
SC542 is a fuser error code and can ONLY BE RESET by a tech. Type pressing clr mode (button) then 107 then press and hold CLR Stop until a menu pops up. turn offf main power then on again. If there is no serious problem the code will not come back. IF it does call a trained tech. DO NOT CHANGE ANY SETTING in the menu that comes up after pressing in the code. YOU COULD RENDER YOUR COPIER INOPERABLE!!!!!!
SOURCE: Error code SC 542 on my Gestetner Dsm622sp
Fusing unit problem.Verify the heater lamps,thermistor and thermofuse continuity.Enter in the SP mode turn OFF the main switch,unplugged the machine wait 10 sec.,plugged and turn ON the copier.
