SOURCE: Plz provive dell motherbord GX 280 windows vista driver.
Hi!
Just checked om Dell site, there arent any specifik drivers for that motherboard for vista.
Here is all the OP that MB GX280 suports.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PLX_GX280&os=WW1&osl=en&catid=&impid=
Good luck
SOURCE: power save mode
Yes, you arent getting a signal to your monitor from your video card. Try replacing. If its onboard then the Mainboard may be bad. These machines are known by Dell to go bad and is covered under warranty, provided you still have it.
The message you are getting is coming from the monitor, not the P.C.
Its telling you you it went into power save since its not getting a video signal from the P.C. Check connections as well.
If your using any kind of splitter, remove it and connect monitor directly to P.C. to be sure.
Good luck
SOURCE: my dell gx 280 just put new ram
Here is the code,Please make sure the memory you used is DDR2 and please rate this a fixya
SOURCE: checkpoint [ithr]
the problem description is
Ithr
Smm mode is initializing the thermal probes.
problably the system is running at high temperature because of improper fan speed, so try to clear the nvram if its not working flash the bios if still the issue persists, replace the heatsink assembly and the motherbord.
