Panasonic KXDT333   Phone Logo
R
Rebecca Wesolek Posted on May 01, 2014
How do i program speed dail #'s on Panasonic KX-dt333?
jalmont
Level 1:
  • Contributor 23 Answers
  • Posted on May 01, 2014
jalmont
Contributor
Level 1:
Answers
23
Questions
0
Helped
7625
Points
32
A system speed dial or using a button on the phone as a one touch speed dial?
If a button on the phone: press program, press the button you want to use, 9, the number, enter
5 Related Answers
cnavarro
Carl Navarro
  • 2460 Answers
  • Posted on Nov 09, 2009
SOURCE: I NEED TO STORE NUMBER ON MY PANASONIC KX T7730
The mechanics of storing a speed dial number on Panasonic phones is the same, even if the phone can be connected to one of 18 different model Key Service Units. It involves pressing PROGRAM a button, an access code, the number, and STORE. In the U.S. our access code to get an outside line is "9". You may be using something different, like '0'.
The differences are if you can dial "9" on the intercom and get a dial tone, which collumn of buttons you press, and/or whether you want this to be PERSONAL numbers or SYSTEM numbers.
In a TA-824, lines are accessed high to low. If you have 2 lines on a basic system and dial "9" to get an outside line, you will land on line 3 if you have not told the system that line 3 is disabled (system program 400). So, the fast answer is press PROGRAM, a button on the right side, dial 9+your desired number and STORE. If it's a left side button, dial 29 instead of 9.
System speed dials requrie access to system program 001.
If this does not work on your system, please comment back with your actual system model number.
Carl
cnavarro
Carl Navarro
  • 2460 Answers
  • Posted on May 07, 2009
SOURCE: panasonic kx-t7633
On the intercom dial *71x1 where x is 0 for all calls, 1 for outside calls and 2 for intercom calls. *71x0 cancels, or you can just press the FWD/DND button until it goes out.
Carl
Anonymous
  • 113 Answers
  • Posted on Mar 24, 2010
SOURCE: I need help setting speed dials on a Panasonic KX-T7730!!
Hello, from the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press Program * # followed by the system password ( default is 1234). Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00. Now enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial. Now press AUTO DIAL / STORE to save your setting. To go to the next speeddial location press SP-PHONE and follow the above steps again. Press Program to exit program mode. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
PLEASE rate this answer if it was helpful.
Thank you.
Anonymous
  • 113 Answers
  • Posted on Mar 28, 2010
SOURCE: speed dailing
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308/824 system. From the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
1. Press PROGRAM * # followed by the system password ( default is 1234).
2. Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00.
3. Enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial.
4. Press AUTO DIAL / STORE to save your setting.
5. To go to the next speeddial location press SP-PHONE and follow steps 3 and 4 again.
6. Press PROGRAM to exit program mode.
7. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
cnavarro
Carl Navarro
  • 2460 Answers
  • Posted on Sep 25, 2010
SOURCE: how do I change name
From the phone connected to Jack 01 or the authorized phone (generally 101) press PROG and dial **1234 Dial 004 and ENTER and dial the ext number of the phone you want to change Use the keypad to enter the name (you have Upper and Lowercase letters) and the arrow key to step to the next character. When you finish, press STORE.
Carl
Panasonic KX-DT333: The switchboard/directory isn't showing 'busy' lines lit up red after recently re-programming phones.
If the busy lines on your Panasonic KX-DT333 switchboard/directory are not lighting up in red after re-programming the phones, it's possible that the programming settings related to the busy line indication were inadvertently modified. Here are a few steps you can try to bring back the feature:
  1. Verify quick dial settings: Double-check the quick dial settings on the phones that are not displaying the busy lines. Make sure that the busy line appearance is correctly assigned to the corresponding quick dial buttons. You can refer to the phone's user manual or programming guide for instructions on how to assign busy line appearances.
  2. Check programming options: Access the programming mode of your Panasonic KX-DT333 system. Look for settings related to busy line indication or busy lamp fields (BLF). Ensure that the appropriate options are enabled or configured to display the busy lines as red.
  3. Restart or reset the system: Try restarting the switchboard or resetting it to its factory default settings. This can help restore any configuration settings that might have been changed during the re-programming process. Be aware that resetting the system will erase all previous programming, so it's crucial to have a backup of your settings if necessary.
  4. Consult the user manual or contact support: If you're still experiencing difficulties, refer to the user manual or programming guide for your Panasonic KX-DT333 system. These resources should provide detailed instructions on how to configure the busy line indication feature. If needed, you can also reach out to Panasonic customer support for further assistance.
Remember to exercise caution when accessing the programming mode or making changes to your system's settings. If you're unsure about any steps or if you're uncomfortable with the process, it's advisable to consult a professional technician or contact Panasonic support for guidance.
Panasonic KX-DT333 Phone. Night Mode Transfer On It.
That would have been programmed when the system was installed. It is done from the control box not from a phone. The technicians connect a laptop to the serial port on the box and program advanced features that way using proprietary programming software from Panasonic. That is how my hotel system was done.
Sometimes you can do it from the reception phone which is the main phone nearest the box, but there is no programming manual available.
https://www.google.com/search?q=panasonic+kx-dt521+programming+manual
How to make a recorded greeting on panasonic kx-dt333 phone system.
http://www.ek-king.com.tw/KX-DT333.pdf
http://eng-ca.faq.panasonic.com/app/answers/detail/a_id/20743/~/how-do-i-record-my-own-greeting-message-for-my-answering-machine%3F
How to edit speed dial feature KX-DT333
To Program:
Lift handset. Press * 3 0 , then enter the desired 2-digit code (00-09), enter the line access code (generally “9”) followed by the telephone number, then #.
To Use:
Lift handset. Press AUTO DIAL/STORE * plus the 2-digit code (00-09).
To Use System speed Dial:
Lift handset. Press AUTO DIAL/STORE plus 3-digit (000 - 999)
The User Guide can be found at the link below. Hopefully this helps.
http://www.manualslib.com/manual/853264/Panasonic-Kx-Dt333.html
1helpful
Speed dailing
1helpful
2answers
Our company has a Panasonic kx-t7731 main line has no dail tone.
On that phone, press PROGRAM the button and dial 01 STORE.
Press program again to exit programming.
It's not likely you'll be needing the Group Log In/Out button.
Carl
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
