Because there are a lot of questions about resizing watch bands, I thought I'd add a tip how to do it. Roughly two types of links are used with Casio watches, so I've added two how-to video's:
? 5:51
https://www.youtube.com/watch?v=N42D4lwD5Ok
Dec 25, 2013 - Uploaded by Phil Crockett
This video shows how to adjust the size of a watch band by removing extra links. This video is "to ... +Jay Carlo Aguilar Glad my video helped you out! Makes my .... Can't wait to challenge my smartass Grandkids to figure it out.
? 6:39
https://www.youtube.com/watch?v=o3NfebIjLlU
Sep 15, 2012 - Uploaded by Nils Rasmusson
Learn how to adjust a metal / silver / gold watch band or how to resize a ... A couple of pins on my watch broke and I bet I caneasily fix this for ...
you dont take pins out of mesh watch bands all you do is put a dart or small screwdriver in the slot to unclamp it slide the clasp were you wont it then lock it in one of the groovs, click link below for instructions please rate me if helped http://mondainewatch.co.uk/how-do-i-adjust-a-mesh-strap.html
Could be a number of different ways. Some newer watches have multiple clasps that make it easier for you to adjust it yourself. Check the bottom of the band for extra clasps.
Without seeing the watch I have no idea what type of links you have. I suggest taking it to a reputable watch repair shop and have them adjust it for you! It will save you the frustration of having to search for a small screw or pin if it should fall on the floor!
If you look carefully on the inner side of expandable bands, there's usually the removable links of the band near one or both ends of the band. These usually have arrows indicating which direction the locking pin/tab slides to unlock and allow removal. If you're careful, you can unlock them and remove one or two by using a small screwdriver. A very inexpensive alternative is to find a local watch repair shop and have them resize if for you while you wait. They've got the mini-tools and it's usually very reasonable (around here, there's a couple chain grocery stores that have watch repair kiosks inside..great alternative and cheap).
If the band is screws then a small screw driver will do the trick. Make sure you use the right size screw driver so you do not strip the screws. If the band is put together with cotter pins you can push out the cotter pins with a small awl or punch. You want to apply pressure to the end of the pin that is not split or appears to be smooth. Usually when you have cotter pins they are arrows or indicators on the band to tell you which way the pins come out. Make sure you put the pins back the same way they came out.
This band requires a pair of band pliers to pull out a U shaped tab that connect the two links. Sometimes you can get a small screw driver in to start the tab coming out and pull it the rest of the way out with a pair of pliers. The tab is located in the middle. You'll note that, if you look at the side of the band, there are three layers of metal. The tab is in the middle and slides out. If you look at the inside of the band, the side that would be on your wrist, you will see the slot that the watch plier would fit into to start sliding the tab out. * I do not recommend this repair for the layperson. I suggest seeing a watch maker/technician.
