Ya sure you can use AT&T sim in Motorola razr v3m only if it is unlocked one .Else if the phone is locked to some other network provider then it wont accept other network sim until you unlock it .You can easily unlock it using code .You can purchase code from sites like WickedUnlock.com they are rendering unlock code for all mobile models at reliable cost .You first check that whether the code is available for your country and network provider .If yes then pay for it and unlock your phone ...
SOURCE: Razr V3M locked
Press and hold the * key then press the center button. It will ask for the security code and the default for it is 000000
SOURCE: How do I remove the Sim card from a Motorola Razr
hello
these are the steps to remove a sim card from motorola RAZR
step 1. Turn off your cellular phone by pressing and holding the power key for two seconds.
Step 2. Remove the battery on the back of the phone by sliding it back and lifting gently.
Step 3. Identify the SIM card, which is under the battery area. A retention strap holds it in place. Don't stretch the retention strap. Slide the SIM card slowly back, up and out of the slot.
Step 4. You may now use the SIM card in another phone, or insert a new SIM card into the Motorola RAZR
