SOURCE: Replace dometic with an electric refrigerator?
I'm not sure, maybe but you could try calling All Seasons RV Appliance Parts & Service they've got cheap recons that you could use. There number is 1-800-344-0673 they have helped me in the past. That and there tech calls are free so it wouldn't hurt to give them a call.
SOURCE: I have a Dometic RV refrigerator Model # NDR1062
My best guess without seeing it is you are not getting gas to the unit
Break the gas supply line at the gas valve with the LP turned on and see if you are getting LP gas
Without the proper water column inch meter it is impossible to tell if you are getting the right pressure, but if your stove top, heater and water heater work then I sill guess you have rubber hoses feeding your refer. Propane and rubber build an oil that will over time plug the supply line and not allow LP to reach the refer. They have to be cleaned out and it is a messy job
SOURCE: prroblem with rv gas refrigerator Dometic ndr1062
I assume you've checked baffle distance above flame? Anything changed above fridge, as in clearance, ventilation above etc. Maybe even removed a piece of panel, that was used above fridge for vent deflection etc?
SOURCE: My Dometic NDR1062 only runs on gas, its set for auto and has 110
There is a control board and a step down transformer that may be at fault.
These should be located in the lower rear of the unit.
