There are some old tapes i have that sound too fast at either speed and i would like to know what all the settings mean, thanks
SOURCE: Dictaphone Expresswriter 2740 Tape Won't Move
The problem is with the capstan motor. More than likely it has developed a 'flat spot' and won't spin up. The clicking noise you hear is the solenoids trying to pull the heads into place, but because the motor isn't turning, it can't pull the heads into place.
SOURCE: lost manual for dictaphone 2750
For transcribing, you'll need the machine (2750), the power supply, a foot control, and a headset (unless you use the machine's built-in speaker).
For dictating, you'll need the machine (2750), the power supply, and the microphone.
SOURCE: 20 year old Dictaphone Voice Processor Microcassette not working
Not sure if you're still having problems with this portable, but the first thing I would check is to make sure that you've put the batteries UNDER the battery clip in the battery compartment. Does the machine just make a 'beeping' noise when it tries to play, rew, or FF?
SOURCE: Dictaphone ExpressWriter system - tape will not rewind, play, ff
Is this a standard-size cassette unit? Is the model number a 2740 or 2750? When you first plug the power in, does the machine make two clicking noises? Does the display show 'CAS' or 'No Cassette'?
