On the normal cycle, not pot.the dishes are not drying.also the dis powder unit does not release all the powder when going thru the cycle.how much is too much powder to add
SOURCE: Kenmore Ultra Wash Dishwasher; Model 665.17539
I have a Kenmore 665 about 3 years old
Over the last couple months the touch pads have stopped working and I am now down to one control the water miser!
Do I need a new control pad and is that easy to install ?
Thank you for any sudgetstions
KC
SOURCE: Whirlpool Gold Quiet Partner IV issue with soap dispenser
This happened to me as well. I think I solved the problem. It started when I first lowered the top rack. In doing so, the door doesn't open all the way. It also won't open all the way if your cutlery rack is in the front and you've put large utensils like a spatula. Consequently, detergent dried under the latch and it wouldn't firmly catch. For months I put up with it never emptying completely. The other day I took a tooth brush and very hot water and cleaned under the latch. After, I could feel a difference in the way the latch operated (with greater pop on opening). So far its been doing fine. Hope this helps.
Denise
SOURCE: Dishwasher stopped drying dishes at end of cycle
There is a heating element in the bottom of the washer. It is burned out and needs to be replaced.
SOURCE: Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Load the appliance with dirty dishes, placing soiled pots and pans on the lower rack where they will be subjected to the most vigorous cleaning. Glassware and dishwasher-safe plastics should go on the top rack. It is not necessary to rinse dishes before loading them in the Hotpoint appliance, unless the dishes have been sitting for awhile and the food particles have dried.
Fill the detergent compartment with your preferred brand of dishwashing detergent, and add glass rinse solution to the rinse reservoir on the inside of the door if your model is equipped with one, then close the door to lock in place.
Select the cycle you wish to use and press the button. For pots and pans, use the heavy-duty cycle. Normal wash is fine for dishes and utensils.
Save on your energy bill by running the dishwasher only when it is full and by allowing the dishes to air dry instead of using the heat dry function on the appliance.
