Heating & Cooling Logo
A
Anonymous Posted on Apr 30, 2014
Gree air conditiones H4 error code
H4 error code
Sumair Ali
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Jul 20, 2017
Sumair Ali
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
16897
Points
Not answer my question is what is the solution for wall mounted unit Model number 18cith1 has error H4 this error meaning here mention system protection.
2 Related Answers
Anonymous
  • 5 Answers
  • Posted on Jan 18, 2010
SOURCE: Gree air conditioning unit turns itself off and
i had this problem it was freezing up outside it was only a short pipe run so it was over gassed i took some out and it was fine
Anonymous
  • Posted on Mar 24, 2012
SOURCE: My new gree air conditioner split system has an E1 error
My greewall mounted has a e1 prblem.how van ifixor what is the problem
H4 ERROR FOR GREE AC RECTIFICATION REQUIRED
Gree AC Error Code: H4
Malfunction Name: System is abnormal
A/C Status: During cooling and drying operation, compressor will stop while indoor fan will operate; During heating operation, the complete unit will stop operation.
Possible Causes: Refer to the malfunction analysis (overload, high temperature resistant)
H4 error code is shown on AC display what can i do to slove this problem
Full list of Gree Air Conditioner Mini Split Units Fault Codes. When error codes appear on the Gree air conditioner indoor display, this tells the user there is an issue with the Gree AC unit. The error code displayed will inform you of the issue or problem that is occurring with the air conditioner. Knowing what the error code means and its definition will help you to understand and troubleshoot the exact Gree air conditioner part that needs to be fixed, cleaned, repaired, or replaced. You can then clean, fix, or replace the Gree part yourself and save money. See below for all error codes that can occur on Gree Mini Split AC's.
Gree Mini Split Air Conditioner Error Codes - How To Fix
Gree Viero AC Mini Split PDF Owners and Troubleshooting Manual
GREE DUCTLESS AIR CONDITIONING & HEATING SYSTEM INSTALLATION MANUAL
Gree Mini Split Air Conditioner Part Names and Locations
INDOOR AND OUTDOOR UNIT
The Gree Air Conditioning Vireo System has onboard error code diagnostics. The outdoor unit will provide status indicators and the indoor wall unit and remote control will display error codes. The following is a summary of the codes with explanations...
GREE AC DIAGNOSTIC ERROR CODES
Gree Vireo Mini Split Air Conditioner Error Code F0
Refrigerant Leakage Protection
1) Refrigerant leak(s).
2) Indoor coil temperature sensor not calibrated.
3) Refrigerant flow is restricted (ex. valve, exv, debris)
Outdoor Unit Red Light Indicator - 9 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E1
System High Pressure
1) Over charged with refrigerant.
2) Blocked or dirty outdoor coil.
3) Extreme outdoor ambient conditions
Gree Vireo Mini Split Air Conditioner Error Code E2
Indoor Anti-Freeze Protection
1) Low return airflow.
2) Indoor fan speed is too low.
3) Indoor coil is blocked or dirty.
Outdoor Unit Yellow Light Indicator - 3 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E4
Compressor High Discharge Temperature Protection
Please refer to the malfunction analysis (discharge temperature, overload) in service manual.
Outdoor Unit Yellow Light Indicator - 7 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E5
Overcurrent Protection
1) Supply voltage is unstable.
2) Supply voltage is too low and system load is too high.
Outdoor Unit Yellow Light Indicator - 5 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E6
Communication Malfunction
1) Communication cable is wired incorrectly between indoor and outdoor units.
2) Indoor or Outdoor control board malfunction.
Outdoor Unit Yellow Light Indicator - Continuous On
Gree Vireo Mini Split Air Conditioner Error Code E8
High Temperature Resistant Protection
1) Incorrect refrigerant charge level.
2) Refrigerant metering device malfunction.
3) Compressor malfunction.
Outdoor Unit Yellow Light Indicator - 6 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code EE
EEPROM Memory Malfunction
Control board malfunction.
Outdoor Unit Yellow Light Indicator - 11 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code C5
System Configuration Malfunction
1) No jumper cap inserted on the control board.
2) Incorrect or damaged jumper cap on control board.
3) Indoor and outdoor units are not compatible.
Gree Vireo Mini Split Air Conditioner Error Code Fo
Pump Down or Gathering Refrigerant Status
Optional Service Mode
Outdoor Unit Yellow Light Indicator - 17 flashes and 1 sec Off
NOTE: All of the Gree Air Conditioner Model Numbers below are applicable for the error codes on this page...
Gree AC Vireo Models: VIR09HP115V1A, VIR12HP115V1A, VIR09HP230V1A, VIR12HP230V1A, VIR18HP230V1A, VIR24HP230V1A, VIR30HP230V1A, and VIR36HP230V1A.
Gree Mini Split Air Conditioner Error Code Charts
Gree Mini Split AC Remote Control Button Names
Gree Mini Split AC Remote Control Icons Display Screen
Gree Mini Split Air Conditioner Air Filter Cleaning Procedure
Need help with error codes on your Gree AC? Please leave a question below and we will be happy to help.
When the indoor unit is on F4 fault error code display.please help to solve the problem.
f4 mean Air Conditioners Questions & Answers - Fixya
www.fixya.com > Forum > Tags > f4 mean
My gree split type ac error F4 what is problem Name of malfunction = Outdoor tube sensor open or short circuit Display of double eight code = F4 this means
Gree air conditioner error codes h5
Gree AC IM getting H5 error code.. how can I fix it?
1helpful
2answers
Code error E7
I'm not sure if NewAir is made by Gree -- they supply many. On Gree units, E7 simply means one unit is requesting heating while another is requesting cooling and you can't have both at the same time. So that's the first thing to check. Very simple, very common, doesn't indicate that anything is wrong with the system.
Gree splet ac i want salution
A Teco unit is almost identical to a Gree. The E5 error on those , it usually means that the outdoor pipe sensor has failed.
Gree air conditioner H8 error code
H8 error means the dehumidifier tank is full, simply drain the water and it should work.
13helpful
4answers
11helpful
4answers
Gree air conditioning unit turns itself off and has an error code of HI dont know what the error codes are
Top Heating & Cooling Experts
Paul Carew
john h
