The hardware setup wizard finds a Via bus master controller but i have been unable to locate and install any driver which will work. The motherboard is a Gigabyte GA-8M800M-775. appreciate any help, have spent hours searching and trying. The Wizard searches the computer and the internet but cannot find any files. I have downloaded include ViaPro, Via_ide_301 and Via_HyperionPro_V524A
SOURCE: M7NCD ULTRA raid drivers
If the SATA drive is operating in 3.0 Gbps mode and your motherboard can only support 1.5 Gbps mode, the drive will not be detected in BIOS or XP. Try jumpering the drive to SATA 1.5 Gbps mode. The label on your hard drive should indicate which pins should be shorted to achieve this setting; if not, look up your particular model on WD's website to find the manual.
SOURCE: What to do with these MOBO driver files? GA-8I945PLGE-RH
download the lan drivers from here (see if the board matches)
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=2156
SOURCE: Gigabyte GA 81845 GVM 775 Soundcard drivers
Hi try this link:-
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=1930
It has all the drivers you need for your motherboard.
Hope this helps.
SOURCE: needs video drivers for GA-k8vm800m
http://www.driverstock.com/download-GigaByte-GA-K8VM800M-driver/30-9-8096/index.html
