To collpase the Bugaboo Frog, follow the steps below:
Ensure that the Frog is in City Mode (small wheels at the front of the stroller).
Standing behind the stroller, push the small white button (located inside the handle bar) and pull both triggers toward you (also located inside the handle bar), then lower the handle bar down to the floor (note - once the handle starts to move dowwards, you can release both of the triggers and small white button).
Once the handle is on the floor, let go and grab ahold of the main central axle (this is the horizontal metal bar which has your serial number sticker on) and lift upwards, this will then allow the pram to fold compactly.
I hope this helps.
Take off the basinette or seat
then, there are 2 knob, sticking out of the sides of the frame, about 6 inches below the handle, from the normal pushing position, hook yr fingers round them and slide them up the frame towards the handle
the handle will drop, then just up the frame from the cross bar under where the set is.
easy once you know how
if it still don't work, go to your local park and accost the nearest person with a bugaboo and ask for some help - there'll be hundreds of them!
SOURCE: Bugaboo chameleon stroller won't collapse
hi there go to www.buggypitsop.co.uk they do repairs to bougaboo and other pushchairs.
SOURCE: how to unfold bugaboo cameleon stroller?
go to www.buggypitstop.co.uk they service and repair bugaboo and have a very helpfull advice you can phone them or email them and they will answer anyn questionsw on bugaboos
