SOURCE: dazzle will only rcord 103 minutes and movies are 120
Are you on Windows? What version (XP, 98, Vista, etc?)
What file system are you using (right click on the drive in My Computer and select Properties)
If you are using FAT32, there is a built in limit to 2GB files. If you are finding that your capture is hitting 2GB (=103min?) and then crashing, this may be your problem. Also, consult the capture settings in the Dazzle software and ensure no file size or running time limitation is selected there.
SOURCE: Pinnale Dazzle DVD recorder doesn't recognize VCR
On the start up of the instant DVD recorder program, you can either use the "let the wizard guide you" or "advance mode"
1. Select source:
you should select the options:
Video standard NTSC (Because this is the default in our region)
Video composite - if you are using RCA (red, yellow and white cables)
S-video - if you are using the cable with several pins in it.
2. Select Burner
You should select the options:
Hard disc folder - if you will be saving the content in your hard drive, the format of this files are DVD such as VOB and IFO etc.
TSST - _ _ _ _ - if you will selecting your DVD drive.
(If you have selected your DVD Burner and you cannot click "next" to proceed to the Third option,
this means that your DVD drive is not able to burn a DVD)
3. Select menus
It must be NO
4. Recording
select total recording time (make sure that dazzle is selected in the "select source" to set the total recording time)
SOURCE: no audio when using "dazzle" dvd recorder
http://www.pinnaclesys.com/PublicSite/us/Products/Consumer+Products/Dazzle/Dazzle+Video+Archiving/Dazzle+DVD+Recorder.htm?view=knowledgebase
Try looking here start there and maybe it will help you out
SOURCE: my computer will not install the dazzle DVC100 driver
Hi and Welcome to Fixya,
The reason why it is now showing because your computer did not detect it. If your Windows operating system is vista 64 bit then go ahead and download the driver in here. www.pinnaclesys.com then click on support, download/Studio and dazzle hardware for vista.
Hopefully it helps you.
SOURCE: my pinnacle instant dvd recorder freezes.
The blue screen is referred to in the industry as BSOD( blue screen of death ) this is a stop screen that is built into Windows to halt on errors whether its a hardware malfunction or incompatibility or software conflicts. Your Dazzle could be faulty or the software is causing the halt screen. This is a major problem with Vista. I have changed most of my computers from Vista back to XP because my Dazzle and new video cam won't run on Vista but runs excellent on the same machine once switched over to XP. Good luck and fell free to Google BSOD for more info.
