I appreciate your post, Tim Davis!
From what you have described your Electrolux dryer is displaying an error code "E63". I understand that you have performed several tests on different electrical components within your dryer. I see you wanted to further test the wiring and I would recommend having a professional technician come out to perform a diagnosis. Since you have completed many tasks there are no instructions I was able to locate that provide further wire testing on your dryer. Best of luck! -Matt
Hello Curtis - Typically, error code E61 indicates a Heater Relay failure. At first the heater was grounded, and now possibly the heater relay. When the heater grounded it could have shorted the relay as well. Generally it is a good idea to have a professional take a look at it to get to the root cause. Cost of parts and technical expertise entailed in these types of replacements can be a bit tricky.
