Question about Canon PowerShot SD1300 IS IXUS 105 Digital Camera
Why lens will not open on cameria - Canon PowerShot SD1300 IS IXUS 105 Digital Camera
What is the max memory for canon ds6041 cameria
Look it up in the manual, or on the Canon website
Jul 09, 2017 | Canon Cameras
Cannot transfer images from cameria to computer
Hi!
A simple workaround is to remove the memory card from the camera and insert it in an appropiate card reader connected to your computer. It allows also a higher transfer speed, that's why I allways do so.
Regards,
Bogdan
Sep 23, 2011 | Olympus Camedia C-3030 Zoom Digital Camera
I have put my memory card in but cannot seem to get my photos to show! Can you help me please?
Have you taken any new pictures with this card? and you can't even see them? if this is the case the card may be bad but the cameria should display meneroy card locked or full or something. If it does'nt they you may need to rerset the camera and it's also possible that the cameria has failed.
Apr 13, 2011 | Cameras
Sony Cyber Shot DSC-T200 The camera motor keeps running creating a blur image I changed the battery but the problem remains
The problem was solved after I called Sony customer support . They directed me how to reset the cameria to its original setting
Thanks
Feb 08, 2010 | Sony Cyber-shot® DSC-T200 Digital Camera
How do i turn non vidio cameria in laptop
simple just go to printers and cameras yours should be there, then right click, then click "set as default device".
Jan 10, 2010 | Compaq Computers & Internet
Hi, I have new laptop and when I conect it with Fe280 Olymous nothing happen
Did you download the operating disk or online operating program for your camera? After that the icon for that programs will be in all programs or in a desktop icon. Click on it and open it and then turn the camera on in the reveiw mode. the display on the carera will ask what you would like to do and the click on it on the cameria and away it'll go. If theses alot of stuff on the cameria it might take quite a while for it to download the cameria onto the computer
Dec 21, 2009 | Olympus FE-280 Digital Camera
I HAVE A CANON POWER SHOT A520. THE ZOOM LENS WAS OPENED AND I DROPPED THE CAMERIA AND THE LENS WHEN INTO THE CAMERIA. NOW THE ZOOM DOES NOT OPEN ANY MORE. THE LENSE IS OPEN AND DOES NOT CLOSE. I GET NO...
I know this is not the answer you want, but when you dropped the camera you damaged the lens tube (housing) and your camera will require professional repair.
Sep 13, 2009 | Cameras
I HAVE A CANNON DIGITAL A520 CAMERIA AND THE LENS IS STUCK IT WILL NOT COME OUT
If you have recently dropped the camera you may have damaged the lens tube (housing). This damage will prevent the lens from moving properly and will cause the camera to shut itself off after a few seconds. If the lens is damaged the camera will require professional repair. If the lens is not damaged, the problem may be battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 12, 2009 | Cameras
It shows dew detected and shuts down, I need to see if is worth repairing and where to send it for repair
A dew message on screen usually means there moisture inside the camera, just store the camera in a warm dry space for a few days so that the components can dry out properly and it should be fine.
Regards
Aug 12, 2009 | Cameras
Canon PowerShot SD1300 IS  IXUS 105 Digital Camera Logo
23 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
