Televison & Video Logo
A
Anonymous Posted on Apr 29, 2014
Thomson 44jw610s the television turns on and the LED blinks, what could be the problem?
Thomson TV black DIVA . Red led light flashes 2 times , then 7 times. Does not turn ON.Need schematic.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Circuit diagrams of many popular brand TVs are given.
What does 3 flashes on the standby light on a Thomson scenium 44jw 611s mean
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given.Surf the site with patience.
My thomson tv shut down every time i turn it on- and the red ligth start to blink it is and: 52jw640 s type 477/1cc21 en
mine do the exact same thing. it might be a problem with the power supply board?? i have no idea, but please tell me if you find a solution
theo
2helpful
My Thomson Intuvia 32 does not turn on?
i think you have a fault in the standby power board.
a kit is availalable for this and can be obtained from www.tvs-services.com or cal 01245392539 monday to friday 9 to 5
Thomson tv projection "52" light blinking.
It apears you have a low voltage problem. This is not an in home repair and may be time to consider purchase of new model. Hope this helps good luck
1helpful
My THOMPSON TV won't turn on!!
Circuit board inside the TV was loose!!
We have thomson tv 32" color crt sort length model 29df45 c s /icc20
tv power goes off when vcd / dish receiver is connected
2answers
Thomson Tv 28 DG 21 K
1)Whenever the word "sometimes" is used,a good visual inspection of PS,horiz,regulation & vert. circuits are needed.Solder any/all bad connects. 2)IHVT aka flyback is the usual culprit. Get part # and ask distributor how popular it is? Any info gathered when doing repairwork can be helpful.!
Top Thomson Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
