Washing Machines Logo
Posted on Jun 21, 2009
The washing machine doesnt start at all. The displayer says: CL.
What does CL means? And how to solve this problem?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 09, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
359
Points
CL means "means chils lock" to disengage hold temp and echo/rapid together and this should solve the problem
I have a CL blinking in the display. How do I reset?
LG Washer Error Code Cl Fix - ApplianceRepairLesson.com
www.appliancerepairlesson.com/.../cl-error-on-lg-washer-repair-help-lg-t...
Jan 19, 2011 - CL means that your washing machine's CHILD LOCK is ON. You canfind ... CL popped up on my display had no idea what it was because the manual didn't say. ... I have the touch screen panel and it does not have temp or option buttons ... I've had tried to reset but won't do do I press temp and what else
How does Child Lock work on my washing machine?
www.samsung.com/au/support/skp/faq/868833
Samsung ElectronicsOct 23, 2015 - If the Child-Lock function is activated, the Child-Lock icon will blink. ...If 30 seconds have passed after opening the cover when the Child-Lock ... Step 5: To clear "CL" error on the display, close the door of the washer after ...
[PDF]Washing Machine - Home Depot
www.homedepot.com/.../d7064d64-8ea1-487d-9c35-a...
The Home DepotJan 3, 2015 - Warnings and Important Safety Instructions in this manual do not ... Donot wash or dry articles that have been previously cleaned in, washed in, soaked ......the Reset water level, "CL" is displayed on the LED display without.
2helpful
Washing machine Siemens iq300 has error CL in display (status) & can't be used
This means that the door is not being closed. It might be a bad door switch.
2helpful
4helpful
CL error message
That means that your washing machines child lock is on. You can find two buttons Temp and Options in the panel. Turn the machine on, press these two buttons together for 3 seconds and thats should be it.
Lg direct drive 6kg, not switcing on properly,
I am not showing a error code for CL, there is one for CE that relates to the main board or the stator motor being faulty.
LG WM1285 WASHING MACHINE
hi Hills659.
this is all i could find out.
What does CL mean on LG washing machine?
LG Washer CL Code Definition (What does it mean?) = The CL Code on front loading LG washing machines simply means the CHILD LOCK feature is turned ON.
The CHILD LOCK feature on your LG washer is meant as a safety precaution so children are not able to change wash settings. CL is not an error code. It is indicating that the CL or CHILD LOCK feature has been turned ON and is active.
LG Washer Error Code CL How To Turn CHILD LOCK Off
14helpful
2answers
LG-Trom Getting error CL .now not able to operate.after switch on it gives CL in display
IE is a water inlet error...meaning that the correct water level was not achieved within 8 minutes or it did not reach preset water level within 25 minutes...
CL is child lock feature which can be toggled on and off by by holding the Pre wash button in for 3 seconds.. Hope that helps...
3helpful
My washing machine does'nt start
Had that problem before. CL means child lock. You need to press the wash and rinse buttons together to unlock.
Machine shows Cl on dispay
cl is over loaded push stop clear to clear then try again with a lighter load
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
