Question about Olympus FE-5020 Digital Camera
Card cover open - Olympus FE-5020 Digital Camera
How to open laptop
Hi Dear...........
If you want open any electronice think you need to complete tool box with first ad. If you have a complete tool then follow the mention instruction and open the laptop, if you don;t know anything about laptop then don;t try to open it.
  1. Reverse the laptop as shown in the figure. And remove the battery. Open the the screws from back side for the Wi-Fi card cover, the modem card cover, the memory card cover, the hard disk cover.
  2. Reverse the laptop as shown in the figure. And remove the battery. Open the the screws from back side for the Wi-Fi card cover, the modem card cover, the memory card cover, the hard disk cover.
  3. Take out the Wi-Fi card cover, the memory card cover, the modem card cover, the hard drive cover. Place them at safe place.
  4. You may require to Open the DVD drive with a paper clip.
    Carefully take out the DVD drive from the computer. In most of the computer one screw from the back site of the laptop fix the DVD Drive. So you have to remove all the screw from the bottom of the laptop.
  5. Insert a thin object under the securing strip(keyboard bezel) and lift it up. Be careful, it may be very tight(there are no screw at keyboard bezel in most of the cases)
  6. Take out the securing strip(keyboard bezel).
  7. Now you can see two screws securing the keyboard and these screws are easily visible remove those screws.
  8. Now careful keyboard is connected with flate ribbon cable to the system board. Disconnect the keyboard cable from the main board and remove the keyboard.
  9. Now you can fine one cable(most probably black colors) from LCD and it is connected to system board. Disconnect the LCD cable from the system board.
    Remove the screw connecting the LCD cable to the base.
    Disconnect the flat LED board cable from the system board.
  10. Carefully lift the display/LCD assembly off the base.
    The display/top cover assembly - LCD assembly and top cover assembly connected by hinges.
  11. Remove the screw securing the HardDisk holder.
    Remove the Hard disk holder.
    Disconnect the left and right speaker cables from the system board.
  12. Now remove five screws securing the heatsink assembly for CPU. And disconnect the fan cable from the main board.
  13. Carefully take out the heat sink off the CPU. And be sure to put heat sink thermal jel /glue when reconnecting the heat sink.
  14. Remove two screws normally at the corner side connecting the system board to the base
  15. Now lift of the system board starting from the left side, be careful with the PC card connector.
  16. Remove the system board off the base.
  17. Modem card is still connected to the system board with screws securing the modem card. If you want you can remove modem card.
  18. Remove the screw securing the optical drive holder.The screw is hidden under the black tape.
  19. Remove the optical drive holder.
  20. Remove four screws securing the card bus connector (PC card connector).
  21. Turn the system board right side up.
  22. Carefully remove the cardbus connector.Unlock the CPU and lift it off the system board.
  23. Turn the system board upside down.Remove two screws securing the video chip fan.
  24. Remove the fan cable on the system board.
    Remove the video chip fan
  25. Hay great techie guy you have done it.
Video :
Part 1
Part 2
Jan 09, 2012 | Computers & Internet
How to remove memory card from camera
Confirm the power-on lamp and the monitor are off and open the battery-chamber/ memory card slot cover. Be sure to turn off the camera before opening the battery-chamber/memory card slot cover.
Removing Memory Cards 1 Before removing memory cards, turn the camera off and confirm that the power-on lamp and monitor are off. 2 Open the battery-chamber/memory card slot cover and press the card in to partially eject the card. 3 The card can then be removed by hand. Do not attempt to remove the card at an angle.
Insert the memory card.
4 Slide the memory card in correctly until it clicks into place. 5 Close the battery-chamber/memory card slot cover.
Oct 08, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Canon Si5 Lens Error message. Have tried suggestions on line
Welcome to FixYa.
There where wo reasons why do you receive a "lens error".
1. CF card slot cover or battery cover opened with camera on
2 . CF card slot cover or battery cover opened while camera was recording to CF card
In this case you have to ensure that CF card cover and battery cover is closed while camera is turn on.
You also need to be careful not to block the camera lens when turning on. Lens will have issues while retracting if your hands or even small thing that will block the lens to retrack while in motion of turning on.
Thank you for using FixYa.
Apr 08, 2011 | Cameras
Have 2 IBM 9068-A01 Dot Matrix Passbook Printer. Both are showing Errors. There is no paper-jam and I have installed 4 different Ribbons, still no joy. First Error code is 0F and the second Error code is...
The cover is not shut all the way or the magnet is not making the connection between the cover and the chassis. A1 is a microcode checksum error. don't know what that means.
Oct 28, 2010 | IBM Network Printer 17 Laser
How do i upgrade my Motorola L9 to 2 gb memory? does the phone support 2gb memory? Amoolya
  1. Open the cover
  2. Find the card slot, look at the bottom part of the unit after you hâve open the battery cover. Tip: Look for the black cover below the battery.
  3. If you have found the little black cover, pull it out, be careful not to break it because its very sensitive.
  4. After you have remove the black cover, put the memory card in.
  5. Close all the things that you have opened.
  6. Turn your phone back on and if the card wasn’t detected, go to settings then memory, then card, then options and then format. Note: only do this if the card you are using does not have any important files at this option will delete all files inside the memory card.
and yes the phone does supporft 2 GB card
Mar 14, 2010 | Motorola Cell Phones
Check card cover- Card cover open
The problem you are describing is a problem with a sensor that is on the card cover door. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $100.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Apr 26, 2009 | Olympus Stylus Verve / ?-mini Digital...
"Card-Cover Open" Warning
Have same problem when camera is used underwater. Take out battery and xd card. Put camera in front of fan with lid open and facing fan for several hours.
May 23, 2008 | Olympus Stylus 790SW Digital Camera
Memory card
1>Open the back cover then remove the memory card.
2>Then take the memory card as well as the back cover
Jan 09, 2008 | Nokia 5300 Grey Cellular Phone
Memory card cover keeps opening while twisting it to a camera.
plz contact vendor for replacement of mobile. body or for replacement of cover of card slot
Nov 10, 2007 | Nokia 3250 Cellular Phone
Olympus FE-5020 Digital Camera Logo
14 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
