The btr message means your battery backup is going bad and you need to change it. Tip the machine back, and on the bottom right there's a battery compartment for 2 AA batteries. Just put in new ones and you'll be set to go!
Remove your instrument cluster and
check the solder joints on the back of the cluster main board. You may
have to flex the board to see the cracks in the solder. Go read the tip
on your code number for a 1998 grand voyager at http://d-tips.com Its quick and free to sign up and they have some great pattern failure tips.
Anti -flood could of activated? now just set to drain , need to disconnect power and pull machine out and tip it back to see if any water is sitting at base of the unit, please remember to put towels under and around the base to catch any such water?
If you have water there it could mean a link , need to tip machine on its back (after removing water by tipping back) undo the 4 screws and visually check for loose or cracked pipes? if loose pipe a simple jubille clip could solve possiable problem?
empty dishwasher clean drain in bottom, close door, check that drain pipe not kinked, tip forward to 45 degree, check pipe again when putting back down, you may have to tip it forward a couple of time if it does not work the first time
Hi luie1177, Flashing the phone back mean to restore ur phones condition as just brought now or to restore to factory settings condition by formatting !!!!! U can format by different methods. one is by using codes and one by formatting as done to other drives in computer with help of memory card reader. ================================================= just send me feedback la. rate my tips. sajan([email protected]/[email protected])
