Westinghouse SK-32H540S 32 in. LCD TV Logo
A
Anonymous Posted on Apr 29, 2014
Westinghouse ld-4258 no picture but have sound
1 Related Answer
Lawrence Oravetz
  • 10558 Answers
  • Posted on Jan 09, 2014
SOURCE: Westinghouse LD-4655VX Power on fine, nice picture, but around 5 minutes turn off self it,
If the set is still under warranty, the power supply board is going bad. If not you can replace it yourself. It's not that big of a job. You can find the parts you need at www.shopjimmy.com
Westinghouse ld 4258 no picture and sound is static or nothing at all
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
LD-2240 problem while trying to set up monitor all I get is no signal to any menu
Search Results
    Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240
    www.amazon.com/...1080p...LD2240/.../B007ATHRJ...
    Amazon.com, Inc.
    Rating: 2.9 - ‎21 reviews
    Amazon.com: Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240: Electronics. ...When I set it up I was disappointed with the sound but not surprised, it is a cheap TV... Apparently this is not an unusual problem for Westinghouse. ... Oh well, I tried. ...VideoSecu Articulating Arm TV LCD Monitor Wall Mount, Full Motion Tilt ...
    Amazon.com, Inc.Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240 ... When I first hooked it up to my cable connection, through the coax connector (TV ... When using as a computer screenthere's an auto adjust and full manual control .... have endured compromised sound and picture, but I've never had this problem. .... Oh well, I tried.
My screen goes black after about 1/2 of watching. It starts to blink and then goes black. I still have sound. Is there a fuse or something I can change?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
How do i add a channel to a westing house tv?
Simply contact their support at the following link: http://westinghouse.com/contact-us/ but know what your model number is (not the serial number).
I think you are not allowing the scanner to actually find the channel before switching out of the menu. I can think of no other explanation for both manual and auto functions to fail (unless you have a lemon).
If you do not have a manual, you can try one of the alternatives below.
Or, you could try to google for the manual for your particular model of Westinghouse TV and find the procedure there. Below I simply list a couple of manuals that may be applicable but clearly are for two models of Westinghouse TVs.
Manuals Online offers a simple to understand procedure (if you can download the manual, I have trouble reading it in my browser for some reason). The information is on page 43 of this alternative. http://tv.manualsonline.com/manuals/mfg/westinghouse/ld265.html?p=43
It has diagrams of the menu.
Pages 35-38 of another manual covers both automatic inclusion and manual addition of channels on a particular Westinghouse TV. http://westinghouseelectronics.com/wp-content/uploads/2010/05/LD-4258-User-Manual.pdf
1helpful
1helpful
Sound went out on my flat screen westinghouse ld-3255. It is less than 2 1/2 years old. Can it be repaired?
If picture is OK, and the fault is with its sound only, the repair cost will be less and can be repaired. Check its speakers first before proceed.
The image display on my Westinghouse 42" LED TV does not fit the screen. It is zoomed in, so when watching sports, i cannot see the score and time ticker.
Using the remote go to the menu for the TV. Look for picture or aspect ratio. Make sure it is set to 16:9 and not zoom or auto. That should clear the problem up.
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
