Has the clutch been disengaged to wind the bobbin? Pulling straight out on the handwheel on some machines will stop the needle from moving so that a bobbin can be attached and wound. If this is the case you simply push it straight back in. Also, on a computerized or electronic machine if the bobbin winding post is pushed right, the clutch will disengage. --Push it all the way left when you are done winding the bobbin to re-engage the clutch. If the problem is internal, like a slipped belt, you will need to have someone open up the machine to repair it. Hope you get it going again!
SOURCE: foot pedal assembly for White sewing machine
You only need to replace the cord if it has been damaged. It will cost less if you just take the machine , cord and control to a local technician and have him just replace the foot control. Let him test it first. A generic foot control should cost less than $30.
sewman7
SOURCE: need instruction manual for alfa 50 sewing machine
CALL EURO PRO 800.361.4639 THEY WILL MAIL YOU A MANUAL
SOURCE: help me find a manual for a euro pro 7133 sewing machine
I hope this helps. It took some searching but this is what i found. Good luck!
http://www.sharkclean.com/manual/7133_REV_1204_ENG-SP-FR.pdf
SOURCE: Singer 258
There is no speed adjust, but 1st you must know the source of the slow down. Remove the belt from the motor pulley and run it, if it goes fast try turning the hand wheel if it is stiff the machine needs clean and oil. If it turns freely you motor may be dirty or just slow. If dirty, sometimes you can without the blet attached run it at full speed for 10 to 15 minutes. It should get faster as you run it. If not motor is weak or slow needs replace. Just replacement motor as genuine probably no longer available.
SOURCE: Euro-Pro 998A Sewing Machine needles
the size & type needle depend on the fabric you use to sew,
try these sites for parts
allbrands.com
searspartsdirect.com
denversewingenginemedic.com
euro-pro.com
sew4less.com
drdanessmh.com
