SOURCE: DPR-1260 ... prints but cannot access web config page
Keep in mind that once you have configured the wireless networking on the print server, you MUST disconnect it from the wired network. It uses the same MAC (aka "hardware") address on both interfaces, so when it tries to participate on both, it fails to be networked at all. Make sure you're only using one (wireless or wired) network at a time.
SOURCE: Problem with DPR-1260
this kind of problem occurs in dlink router sometimes & after some time router stop responding after 10 -15 min & once u reboot the router it again start work for a while. the best solution to this problem is to reset the router back to its factory defualt settings u can do this by press the reset button on the back on the router ( it looks like a small hole u have to use a pin for press that button) once u have reset the router to factory default settings just reconfig the router & i am sure it will start working fine in case u still face the same problem just contact D-link or send me the details about the problem & the physical setup of ur router & printer etc
SOURCE: D-Link DP-301U Problem
i cannot get my ip address after i press the reset button at the print server DP-301U. How can i get?
SOURCE: I have installed the DP-301U print server on my
Your print server has to have its own IP address. If you have your computer as 198.168.1.1 then your print server would be 198.168.1.2.
You cant have the same IP address on any 2 items on your network.
SOURCE: D-Link DPR-1260 print server setup problem
Try admin for logon & password.
Sometimes it is user ......
