Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
A
Anonymous Posted on Apr 28, 2014
Why are all lights out router
Dynex router
Logan Simonsen
Level 1:
New Friend:
  • Contributor 24 Answers
  • Posted on Aug 13, 2014
Logan Simonsen
Contributor
Level 1:
New Friend:
Answers
24
Questions
0
Helped
5648
Points
27
1. not plugged in
2. bad outlet
3. the on/off switch on the back is set to the off position
4. bad power supply unit
if it doesn't turn on after checking all this then you need a replacement.
Can the LED lights burn out on dynex routers
Short answer - yes. Any lamp can burn out. It can also indicate a port that has gone bad, too. It there's no data getting in or out of port #2, connect the cable in #2 to a different port (1,3, etc.) if it works there - then port 2 is dead. Avoid using #2 port or replace the router.
How to connect a dynex (dx-e402)router to linksys (befsr41) router
Configure the dynex on another computer that is not connected to the linksys router.
Assuming that your linksys is currently setup as 192.168.1.1
Turn off DHCP on the dynex and setup the IP to 192.168.1.2 subnet mask 255.255.255.0 gateway 192.168.1.1
use a cross over cable and plug each ends to the LAN port on port routers.
you should now be able to ping 192.168.1.2 (dynex router) from your other computers on the linksys router network.
any computer that is connected to the dynex should be able to get a dhcp address from the linksys router.
My computer is not connecting to my Dynex wireless router. I've called my locate cable subscriber and they told me that it's a router problem. I've disconnected the router several times and it shows that...
First off, verify that you can connect to your cable modem directly. After that, hook up your Dynex wireless router and reboot your cable modem. After this, directly connect your computer to the Dynex router (using a cable). If you cannot get an Internet connection, then there is some issue with your Dynex router configuration. It's possible that there might be an IP address conflict with the cable modem. It would be best to contact support for configuring the Dynex.
If you can connect to the Internet with your computer connected directly to the Dynex router, then there must be some router configuration problem affecting your ability to connect wirelessly. You'll have to check the configuration--might be a good idea to completely reset the router and start over. If that doesn't help, you should contact Dynex customer support, as each router has its own configuration specifics. Good luck.
3helpful
Need software for Dynex 10/100M router
no, you do not need software for your router, you need manual. there is no router which need software installed on the computer. try download manual from this site:
http://www.dynexproducts.com/products/computers/DX-E402.html?supportTab=open
I'm trying isolate parts of my network and I need to place a Dynex 4-port router right after my modem and then plug my office lynksys router into that. (At present, the linksys is plugged into the modem...
Modem <--> Dynex <--> your computer should work.
Connect:
Modem <--> Dynex <--> Linksys router <--> your computer.
Turn off all the above devices.
Turn the modem on, and wait for its lights to "settle" down to a repeatable pattern.
Turn the Dynex on, and wait for its lights to "settle" down to a repeatable pattern.
Turn the Linksys on, and wait for its lights to "settle" down to a repeatable pattern.
Turn your computer on, and wait for its lights to "settle" down to a repeatable pattern.
On your computer, click Start
Click Run
Type CMD and press ENTER
Type IPCONFIG and press ENTER
The Linksys router should have given you an IP-address for your computer, and the IP-address for the "gateway" (namely the Linksys router).
Start your web-browser.
Type http://192.168.0.1 (or http://192.168.1.1) to connect to the web-interface "inside" the router.
Access the 'WAN' settings-page on the router, to see what IP-address the Dynex router has given to the Linksys router, and what "gateway" IP-address that the Dynex router has offered to the Linksys router.
It might be best to change the range of "dynamic" IP-addresses that one of the routers hands out, e.g., '192.168.123.100' to '192.168.123.200' for the Dynex router, so that both routers don't try to hand-out IP-addresses in the *SAME* range.
My dynex router lost power. If I unplug it then
Try to reset to default (page 8 User Manual):
http://www.dynexsupport.com/sites/dynex/dl/DX-WEGRTR_07-366_Final%20CD.pdf
If this not work, try to contact Dinex Support:
http://www.dynexproducts.com/t-contact.aspx
4helpful
Dynex-e402 change nat settings to access x-box live
Dynex DX-E402 router, changing NAT settings(UPnP) to access x-box live. go to router settings web page for router, http://192.168.1.1/, enter user name and password to access settings page. user id is usually admin this also for password. under advanced settings click on forwarding. In listed sub-catagories click on UPnp. click enable. this should solve any NAT issues with X-box 360 signing onto x-box live. dynex dx-e402 was very easy to setup.
1helpful
Cannot connect to internet using Dynex Wired Router
First, power down all equipment.
Second, plug in power to modem, let all the lights come on and boot up
Third, plug in the router power and let that boot up and the lights come on
Fourth, Plug in each pc to the ports labeled 1-4
The WAN port should be connected to the Modem also.
Top Actiontec Computers & Internet Experts
Jesse Walters
Jesse Walters
NOEL
NOEL
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
