I have a white one of these tablets and it has a error after i log onto the main screen that saysa something about an error and force close button and every time i try to get the box to go away it keeps popping up do u have any idea whats wrong with it and what i can do to get it working?
This is about the worst tablet you can ever buy
in the future spend more than 80 bucks either way here is the help you need to fix it it is called a hard reset
How to hard reset Pandigital Novel 7 to Factory Default Setting
Reset Pandigital Novel 7 to factory default setting you will lose all of your sms and apps,so you must back up your apps and sms.
These steps will show you how to hard reset Pandigital Novel 7 to factory default settings:
First, try this:
1. Go to main home screen, press the menu button.
2. Choose the Privacy
3. Press Factory data reset.
4. Read the disclaimer, then Press Reset.
5. Last,press Erase everything.
6. Restart the Pandigital Novel 7, you will see the phone as a brand new phone.
SOURCE: pandigital novel 7" WHITE ereader wont turn on.
You
can try pressing the reset button with a straightened paperclip of pin.
If that doesn't do anything removing the back and unplug the battery.
Leave it unplugged for a minute or two and reconnect it. Be careful
unplugging it as you don't want to put to much force on the wires. You
can use a small screw driver or tweezers to pry on the plug. The white
plug here
is what you're locking for. See if it powers on and hopefully it does.
If not you may have to contact Pandigital.
Hope this helps
Ray
SOURCE: have a white screen on tablet can' turn off nor on pandigital
Very gently unplug the battery cable for two minutes.. I used a pair of tweezers and worked it out. Plugged it back in and it is fine. What a relief. I have read that if it goes to sleep while plugged in via usb, it freezes? Don't know. Just be careful when pulling the battery!
