I have followed the manual recorded my message then listened to my message but when I press submit it beeps an error tone at me. Then when I phone up & listen it is not my message
Hi Tourmaster,
I have these steps for you on how to do it. Hope it helps.
Mailbox Greeting
While the voicemail system will play a generic greeting to caller, prompting them to leave a message, you can record your own greeting.
1.
Press the MESSAGES button. Depending on how your system is configured, you may be required to enter your voicemail password and then press the Done soft key. The visual voice menu is displayed.
2.Use the up and down arrow keys to scroll to the option Greeting.
2.Press the Select soft key or OK.
3.
Use the soft keys to listen to and record your mailbox greeting.
Listen
Listen to the current greeting or the new greeting just recorded.
Record
Record a new greeting. Note that the greeting must be at least 3 seconds long or the voicemail system will discard it.
More
Switch between the different sets of available soft key functions.
Submit
Submit the new recording as your mailbox greeting.
Delete
Delete your current mailbox greeting. The voicemail will use its default greeting.
- To Access Supervisor Options:
- From main menu, press 6 for Supervisor Menu
-Press 2 for Routing Box Administration
-Enter Box Number that you are changing / recording
(Main Day Greeting is box 800, Main Night greeting is box 801)
-It will repeat the number you entered and prompt you to press 1 if its correct
-Press 3 to Modify
-Press 1 for Greetings
-Press 2 to Record Greeting
-Press 1 to replay current greeting or Press 2 to record greeting
-Press * (star) for current greeting
-Record greeting.
