RCA DRD480RE Receiver Logo
A
Anonymous Posted on Apr 27, 2014
Onkyo TXSR600 code for Directv remote
Programming throughout the system setup doesn't work. Is there another code?
Billy
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 89 Answers
  • Posted on Nov 24, 2014
Billy
Expert
Level 2:
New Friend:
Night Owl:
Answers
89
Questions
0
Helped
19884
Points
117
Go to Directv.com and look under remote control programming.Then enter your device name, it will give you the most recently used codes for your device.
Onkyo volume control code on directv remote
It depends on the remote. If you have the long rectangular remote then it will only work TVs, not sound systems. The smaller curvy remote will do sound systems. But not every make.
Programming is done by following the onscreen guide.
If there are no codes for your Onkyo receiver, and there's no way to do a "search all codes" type scan, then you have to acceppt that it's a limit of the remote because it doesn't have the right codes in its memory.
2answers
I need to program my pionner sx-315 reciever in my directv remote control
I can help you with your Pioneer Receiver & DirecTV remote control.
This is a list of all the Pioneer Receiver control codes for DIrecTV remote controls:
31023, 30150, 30244, 30289,
30531, 30630, 30801, 31123,
31343, 31384, & 31935.
There are so many codes to try for Pioneer Receiver and DirecTV, you might want to go ahead and do a DirecTV Remote Control Code Search.
I hope that helps.
_________________________________________
DirecTV Remote Control Code List Download
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Entry
DirecTV Remote Control Onscreen Setup
I lost my remote and need to switch the tv so I can get Directv - how can I do this without my remote
I can help you with your Toshiba TV & DirecTV remote control.
To get your TV setup so that you can view your DirecTV on it, I recommend you program your DirecTV remote to control your TV and then use the DirecTV remote to change the input of your TV to view the DirecTV programming.
You can choose between searching for the control code and
entering a code from the Toshiba TV list.
This is a list of all the Toshiba TV control codes for DIrecTV remote controls:
11524, 10154, 10156, 11256,
10060, 12006, 11945, 11936,
11935, 11918, 11704, 11656,
11635, 11369, 11356, 11343,
11325, 11306, 11156, 10845,
10832, 10822, 10650, 10149,
10148, 10036, 11971
I hope that helps.
Onkyo 605 loss of audio on HD channels only
on your directv box, go to menu, setup, setup again, then audio, then dolby digital on the right and turn it on. assuming you have an optical audio cable from your sat box to your onkyo.
Follow setup instructions and still does not work
you are not sliding the switch at the top to tv mode do that and input code 10000 it should work
18helpful
3answers
CORRECT SETUP CODE FOR RECEIVER
Originally Posted by 3FingeredGlove viewpost.gif We can make this work. You didn't mention which setup code you're using, or explicitly say whether the OK/Select button is red or gray (the manual you're using is for gray), so these are somewhat generic instructions. Should work, though. This will provide a power toggle function to the Power key.
Use red numbers for the red OK/Select button remote, grey numbers for grey button remtoes.
Temporarily assign setup code 30842 or 0842 to AUX
1) Tap AUX
2) Press Setup until 2 blinks
3) Enter 30842 or 0842The remote should blink twice
Assign NEC1 IR protocol device 210, subdevice 108, function number 203 to Power (you don't need to understand these numbers)
1) Press Setup until 2 blinks
2) Enter 994 (2 blinks)
3) Tap Setup
4) Enter 00051
5) Tap Power (not All On)
Assign setup code 30135 or 0135 to AUX (this is NEC1, 210.109)
1) Tap AUX
3) Enter 30135 or 0135
5helpful
2answers
Directv remote codes
go to menu
setup
setup again
remote
tv
brand
the satelite receiver will tell you the procedure for programing the remote
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
